Dome Light Problem
Old 09-24-2005, 08:35 PM
samcarroll's Avatar
Dome Light Problem
Hey all
The dome light works for the passenger side door but not the drivers side. And i live on a corner and its dark on the side street so id like it to work. I have checked te door "plunger" and it goes in and out but im not sure why its not working.
Old 09-24-2005, 08:42 PM
Elton's Avatar
it might be unplug does the key chime work ?
Old 09-24-2005, 08:48 PM
samcarroll's Avatar
No it doesnt. Im not familiar with toyotas so what do i need to do to fix it?
Old 09-24-2005, 08:53 PM
Elton's Avatar
what u do is take the kick panel off its easy 2 do like 10mins reach in where the plunger is there should be a wire in the back there if its unpluged just plug it in and it should fix it
Old 09-24-2005, 08:54 PM
samcarroll's Avatar
The plug should just me there dangling close? Just trying to get all the info i can get to make it easier.
Thanks again.
Old 09-24-2005, 08:57 PM
Elton's Avatar
mine just has a conector u just pull apart
Old 09-24-2005, 10:22 PM
samcarroll's Avatar
I went out and checked it out and solved the problem. Thanks
It was just like you said, was just sitting there unplugged.
Thanks again
Old 09-24-2005, 10:25 PM
Elton's Avatar
ur welcome
Old 09-25-2005, 04:16 AM
Rick F.'s Avatar
Location: Far western Kentucky (transplanted from central PA)
GOSH, I LUV this site!!!
Old 09-25-2005, 06:05 AM
waskillywabbit's Avatar
I was reading this hoping for an answer...
My dome light comes on w/ the passenger side as well, but not the driver's side. HOWEVER, when I open the driver door the door light in the door comes on, just not the dome light. When I open the passenger door, the door light comes on and the dome light. I'm beginning to think this is just how it is supposed to be. This is an 1985 4Runner.
Old 09-25-2005, 06:39 AM
4Crawler's Avatar
My '85 dome light comes on with either door open and the door lights come on when that door is open. Could be the blocking doide for the driver's side door or the connection to the dome light is missing. Both switches tie together w/ a pair of diodes to ground the dome light when in the automatic mode.
Old 09-25-2005, 06:47 AM
I looked at the connections yesterday. There is a plug into the plunger on the driver's side, and like I said, the door light works when I open the door, so the plunger is good, just the dome light don't work w/ the driver's door. I hate to think about trying to trace the wiring blind...got a diagram/link anywhere for this?
Old 09-25-2005, 06:55 AM
4Crawler's Avatar
Wiring diagram in the Factory Service Manual, basically:
Code:
Battery
Fuse
Dome  Door
Light Light
Diode  |
Switch
Ground
Old 09-25-2005, 07:19 AM
:pat: I got one of those...I hope it has a diagram of where to look for things...I hate wiring, but I'd like to have the dome light come on when I open my door for sure...
Thanks Roger, I need more coffee this morning.
Old 09-25-2005, 07:28 AM
4Crawler's Avatar
I think the wiring just runs up the driver's side a-pillar.
Old 09-25-2005, 11:28 AM
If that is the case...that would explain a lot...only wiring in that spot is wiring I put there for my a-pod gauges. Gotta dig out the FSM when I get a chance. Thanks.
Old 02-06-2012, 04:35 AM
toy2005's Avatar
Hate to bring up an old thread, but anyone know where this blocking diode is for an 87'? My passenger door works, but drivers doesnt.
Sleaker
08-26-2020 06:03 AM
the1998sr5
15
07-14-2020 08:35 PM
rushw
07-18-2015 01:46 PM
msane99
07-11-2015 08:08 PM
madxman21
07-09-2015 10:26 AM
Quick Reply: Dome Light Problem
