Distributor grease?
Old 02-16-2005, 10:48 PM
the_supernerd's Avatar
Distributor grease?
I am planning on doing a partial rebuild on a distributor for my truck. Should I put some kind of grease on the mechanical advance? What kind?
Old 02-16-2005, 11:22 PM
jimbo74's Avatar
di-electric grease might be ok... i wouldnt mess with it too much though... grease has a tendecy to accumulate dirt and grit, and this cuases binding and premature failure due to wear
Old 02-16-2005, 11:35 PM
Do you know what it uses from the factory?
Old 02-17-2005, 08:18 AM
kyle_22r's Avatar
i never knew it had grease in there. i'll take a look at my FSM and see if it shows anything.
Old 02-17-2005, 12:14 PM
I just got a factory service manual for my truck and it says to put grease in the shaft that has the rotor on it, but it does not say what type of grease.
Old 02-17-2005, 02:04 PM
kyle_22r's Avatar
i figure some hi-temp wheel bearing grease would do the trick.
Old 02-17-2005, 04:48 PM
Thanks for the replies. I think I have some hi-temp wheel bearing grease, so I will use some of that.
JonG85
01-18-2023 04:31 PM
kawazx636
10-06-2021 03:03 PM
ladybugRC
458
08-21-2020 10:41 AM
LittleUgly
15
01-02-2020 01:30 PM
seab1209
09-03-2015 05:41 PM
Quick Reply: Distributor grease?
