Cylinder Misfire?
Old 03-05-2008, 07:12 AM
Quattro15's Avatar
Cylinder Misfire?
So here's a brief synopsis of what's going on...
I had a Cylinder 3 misfire yesterday. I changed all spark plugs and that didn't fix it. I then changed the coil pack from Cylinder 3 to Cylinder 5 and the other back to cylinder 3 of course...ran like a charm. It's ran well until today when I was getting on the highway, Check Engine Light came back on.
Now it's a cylinder 5 misfire.
What's going on? A friend of mine says it could be the wires while I'm thinking it's the coil pack.
What do you all think??
I have a appt with my toyota dealership tomorrow to get it looked at, but I'd rather not spend the money there if I can fix it at the house.
Thanks!!
Old 03-05-2008, 07:17 AM
warriors_03's Avatar
If you only moved the coil pack and not the wires, then its definitely a coil pack. Swap the coil pack, and save some $$. Depending on how old the wires are, a new set wouldn't hurt anything either.
EDIT: You can order the parts for cheaper from trdparts4u.com. They are prolly cheaper than the dealer new you including shipping.
Old 03-05-2008, 07:22 AM
Quattro15's Avatar
But wouldn't the coil pack affect two of the cylinders??
Old 03-05-2008, 07:46 AM
MTL_4runner's Avatar
Not always.......but warriors_03 is also not correct that it automatically means you have a bad coil pack either. There are alot of reasons for misfires and you need to do diagnosis to figure out exactly what the issue really is.
Old 03-05-2008, 08:07 AM
Quattro15's Avatar
So is my best bet to get it down to the dealership for a diagnostic? It's $40, so it's not like it's a bankbuster.
Also, do you all think it's ok to drive it there?
Old 03-05-2008, 08:36 AM
MTL got me on that one...thats more of a gut reaction from me...
$40 bucks for a diagnose from the stealership? Damn thats cheap. Here it is $95...I would definitely do that then...
Old 03-05-2008, 08:43 AM
jukeit's Avatar
If you moved just the coil pack from 3 to 5 and the problem followed the coil pack, I would roll the dice and just get a new coil pack. The problem followed the part so in my opinion you can confidently swap it out.
Old 03-05-2008, 08:51 AM
Quattro15's Avatar
My mechanic buddy said that since the truck ran fine for a while then it's probably the wire that connects to the coil pack. Since it would heat up and then not carry a good signal to the coil pack.
Should I try the wire first? Where can I get one of these?
Thanks for the help!
Old 03-05-2008, 08:55 AM
jukeit's Avatar
But if the wires were not swapped, then it would be a pretty odd coincidence that the original cylinder 3 problem followed to cylinder 5. If the only part that moved was the coil pack, then I would replace that.
Old 03-05-2008, 09:04 AM
Quattro15's Avatar
What I'm actually talking about is the wire that comes from the coil pack to the spark plug.
Old 03-05-2008, 09:26 AM
Quattro15's Avatar
And can you just get that wire that goes from the coil pack to the spark plug?? I can't get the wire by itself at Advance Auto.
Thanks!!
Old 03-05-2008, 10:04 AM
Quattro15's Avatar
Well, I got a new coil pack and it works fine. Unfortunately all I needed was the boot that runs from the coil pack to the spark plug as I can see where the coiled wire inside is broken.
$70 bucks now is better than $40 bucks tomorrow and then spending money for parts.
Old 03-05-2008, 11:51 AM
98runner210's Avatar
I got my coil packs off eBay dirt cheap and brand new. They seem to work great and have a 2 year warranty.
Old 03-05-2008, 01:18 PM
jukeit's Avatar
Ah. You were talking about the little "spring"/wire inside the boot. Gotcha. Glad you got it fixed.
Old 03-05-2008, 02:04 PM
Adam F's Avatar
Yup, had to be the plug wire since the coil pack gives spark to 2 cylinders, and you would have had 2 cylinder misfires if the coil pack was bad.
Save the old coil pack for a backup.
Old 03-05-2008, 05:45 PM
Quattro15's Avatar
Is there anywhere that I can get that plug wire without the coil pack?
shooter86314
01-07-2016 07:05 AM
Obmi
11-24-2015 11:37 AM
calderp
11-16-2015 02:49 AM
eggens
10-27-2015 03:14 PM
larrys93pickup
09-17-2015 07:05 PM
Quick Reply: Cylinder Misfire?
