Crap! O2 sensor Replacement Problem. Help!
Old 12-04-2004, 11:22 AM
DrummerDaveB's Avatar
Im trying to replace my oxygen sensor, and I found that somebody has (at least) removed it in the past. They to tally screwed it up for me.
The nuts to remove it were all tore up. Every point on the nuts were tore off, and they of course didnt bother replacing them after destroying them.
I managed to get an 11mm wrench on one, and got it off, but I cant get the other one off.
I've tried using 12mm 6point, 12point, 11mm 12point, and a pair of those self adjusting pliars to get it off, and it wont budge.
What should I do?
Old 12-04-2004, 11:28 AM
nunsa's Avatar
What should I do?
You need a torch to heat them up and some vice grips, works every time!
Old 12-04-2004, 12:40 PM
Flamedx4's Avatar
Vice grips.
Old 12-04-2004, 01:32 PM
3car's Avatar
go to your local sears store and get this, they work like a charm. snap on also makes a set, but...they wont replace them if they break.
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
Old 12-04-2004, 02:43 PM
MTL_4runner's Avatar
You can also try to split the nut with a dremel tool and a cutter wheel if you have one.
I am sure one of the other methods will work as well.
These things do work well too (as was mentioned):
RyanJ989
11
04-07-2021 09:41 AM
Ronnyboy
02-11-2016 05:57 PM
Draven023
11
10-01-2015 06:47 PM
shredder4286
10-01-2015 01:09 PM
Quick Reply: Crap! O2 sensor Replacement Problem. Help!
