Crankshaft pulley issue during removal
Old 09-16-2012, 04:38 PM
TxRiverRat's Avatar
First post, long time lurker. I started on the timing belt replacement today on my 98 4runner with the 3.4L and ran into an issue. I've done a lot of shadetree work on my cars in the past but this is my first timing belt.
I used a homemade SST to break loose the crankshaft bolt which used two pins that slid into the 3/8" holes on the pulley. After cranking on it, I felt a pop and figured it was the bolt but it turned out that the doughnut looking center part of pulley broke off. If its unclear, see the pic below in which I highlighted the section that separated. It looks like it's attached to the main part of the pulley with a rubber seal.
I managed to get the pulley off using the starter bump method but I have a few questions:
1) What is that center section? The damper?
2) Is the pulley toast? The crankshaft bolt clears the inside of the doughnut thing so I don't see any way of holding the doughnut on.
2) Should have I bolted the SST to the pulley to prevent this?
Thanks in advance.
Attached Thumbnails Crankshaft pulley issue during removal-crankshaft-pulley.jpg
Old 09-16-2012, 04:45 PM
rworegon's Avatar
Yes, it is a rubber damper and, yes, the pulley is toast, AFAIK.
I doubt bolting the SST would have prevented it. Did the woodruff key in the crank break or round off?
Old 09-16-2012, 04:59 PM
TxRiverRat's Avatar
Thanks for the quick reply. The woodruff key looked fine but i'll take a closer look at it tomorrow in the daylight. Guess I'll be hitting up the junkyards tomorrow...
Old 09-16-2012, 07:09 PM
TheDurk's Avatar
This is one reason the much maligned starter-bump method of removal is actually the way to go. JMHO.
Old 09-16-2012, 08:23 PM
forrest232's Avatar
Yup I learned and expensive lesson doing it that way, make sure woodruff key is fine then get a new pulley and use a chain wrench for torquing it down .
Old 09-17-2012, 10:24 AM
TxRiverRat's Avatar
I checked the woodruff key, no damage.
See pics below for the actual crankshaft pulley and separated damper. The damper is just held on by a rubber seal.
When I was reading up on changing the timing belt, I saw several pulley holding tools that used pins, 3/8" drill bits, etc. It's obviously a really bad idea to rely on that rubber seal to hold up to the amount of torque required for the crankshaft bolt.
The starter-bump method worked great, broke the bolt loose on the first try. For torqueing the new pulley, I'll be bolting the pulley holder on or using a chain wrench if I can find one locally.
Attached Thumbnails Crankshaft pulley issue during removal-img_20120917_082545.jpg
icentropy
09-16-2020 02:47 PM
jasonty
41
12-23-2018 01:00 PM
irritech
07-27-2015 05:15 PM
PlayAwhile
07-20-2015 11:36 AM
dinks07
07-15-2015 05:34 PM
Quick Reply: Crankshaft pulley issue during removal
