Crankshaft bolt felt out -- bye bye crankshaft
Old 04-04-2007, 05:29 PM
  #61
mt_goat's Avatar
Yeah the spec I have for the 3vz-e is 181 ft-lbs.
Old 04-04-2007, 05:37 PM
  #62
Uncle Vido's Avatar
Ahhhhhhhhhhhh 181
Thanks MT. I was wondering about that. I am still going to go in and make sure that everything is done right. I just want to keep going untill I get the bucks up for another engine. Hell I was going to tell them to just weld the Crank Pulley on. I am glad they saw it my way.
Thanks MT I am off to Hunker down. I will be back with results tomorrow.
Old 04-04-2007, 06:40 PM
  #63
Mark in MD's Avatar
Gotta give that chick credit. For one post, she created a very nice, informative, and instructive thread. Too bad she apparently never came back to read it.
Old 04-06-2007, 05:08 AM
  #64
Uncle Vido's Avatar
Well now I find out today after they get all the work done that the non english speaking mechanic that did the actual work has a Torque Wrench that only goes to 150 lbs. Then I went off on them and asked them what they did to get it to spec. They said we used the impact gun. WHAT!!! I said.
Now I have to do it myself. My check engine light comes on intermittently now. What might that be? I will let you guys and Gal if she ever comes back know of the saga.
Old 04-06-2007, 05:27 AM
  #65
mt_goat's Avatar
Yeah that's the universal sign for "I'm a lazy, half___ed, sorry excuse for a mechanic". I'd drop that shop like a dirty shirt. I found a torque wrench that goes to 250 ft-lbs at Home Depot for about $70.
Old 04-06-2007, 05:31 AM
  #66
mt_goat's Avatar
Pull the code and go from there. That's the nice thing about computers in vehicles now, they can tell you where to look.
Old 04-06-2007, 06:08 AM
  #67
gpcollen1's Avatar
I usually wait til Sears has one of there big tool sales and then see what is marked down.
Old 04-06-2007, 06:31 PM
  #68
Uncle Vido's Avatar
Cool Mechanic Shop is now off my list
Driving around today I am still getting the intermittent " Check engine light" It runs good and strong until the light comes on. I asked Jose to tell me what it was. In broken english he said the O2 sensor. I replaced that 5 months ago. I am heading to Sears and then Pep Boys. Find me another Torque wrench and take things into my own.
I am strongly moving towards getting a remanufactured some time in the near future. Know of any reputable shops out here in Los Angeles area?
Oh yah now I have an exhaust leak somewhere. I can tell by the sound. It sounds like a semi tractor (Kenworth) when Slowing down.
I will continue the story later.
Wonder what happened to that poor gal?
Old 04-06-2007, 07:32 PM
  #69
Mark in MD's Avatar
I dunno. It's too bad. She created a great thread. I bet she would have been a nice addition to the "Girls of Yota" thread too. Just a hunch.
Old 04-07-2007, 05:13 AM
  #70
mt_goat's Avatar
If the leak is before the O2 sensor that could be what the CEL is. Fix the leak and try that.
Old 04-07-2007, 02:43 PM
  #71
Adam F's Avatar
I worked at a Toyota dealer for 6 months, and I don't ever recall seeing a torque wrench being used, ever.
Old 04-07-2007, 02:49 PM
  #72
MTL_4runner's Avatar
Most of them don't, they just use an impact gun (usually gets the bolt to about 250-350 ft-lbs that way). As long as you don't hammer on it too badly (which most pro mechanics know not to do) the bolt will be plenty tight enough to prevent working itself back out. Problem is you don't really know how tight or loose it was when the vehicle goes out the door (you'd only know if it came back with an issue).
Old 04-10-2007, 05:35 PM
  #73
Uncle Vido's Avatar
Cool Truck Runs Cooler Now
Well with a new shroud and new Fan and new Crank Pulley it does run so much cooler. I tried the Torque wrench and it went to around 225 lbs. per ft. I haven't had time yet to zero in on the Gasket Leak. My guess is that it is before the Cat. Conv. Would that make the engine adjust to sending more fuel into the Piston Chambers? Just wondering since I see smoke (not much) until it's warmed up.
MT Whats a CEL?
Thanks again you guys. I will continue the saga.
Old 04-10-2007, 05:51 PM
  #74
Staff
DeathCougar's Avatar
CEL=Check engine light
1uzRunner
63
11-10-2018 03:58 PM
Pocoyota
09-08-2015 02:41 PM
Jwp1
09-06-2015 11:03 AM
eggens
09-05-2015 12:16 AM
Aaron Logan
09-03-2015 08:08 AM
Quick Reply: Crankshaft bolt felt out -- bye bye crankshaft
