Cracked air box. Fixing ideas
Old 07-30-2010, 03:24 PM
j-money$$$'s Avatar
I have about a 3 inch crack behind my air filter on the air box. it needs to get fixed because it is behind the filter.... I was thinking about jb welding the plastic back together. but i do not know how sensor safe jb weld is. any ideas
the pic shows the crack
Old 07-30-2010, 03:38 PM
totally a bro
Staff
vital22re's Avatar
could you torch a piece of metal and use it to "weld" the plastic together?
Old 07-30-2010, 03:43 PM
Staff
DeathCougar's Avatar
You can also epoxy it back together, to close up the hole. I have seen some plastic-weld stuff works pretty good too.
http://www.google.com/products?hl=en...ed=0CDcQrQQwAA
Old 07-30-2010, 05:28 PM
DailyDrive's Avatar
Aluminum duct tape, easy and practical.
Old 07-30-2010, 05:42 PM
2DoorRunner's Avatar
PO drilled a bunch of holes in the bottom of mine. Used silicone to plug them up.
I would melt it back together, then use silicone or something like that to seal it off.
Old 07-30-2010, 05:49 PM
Yukon's Avatar
Duct tape. Or sensor safe blue RTV and glue hte pieces back together
Old 07-30-2010, 06:21 PM
aa1911's Avatar
you don't HAVE to use sensor safe glue, it just needs to dry before you use the truck! wouldn't hurt to be double sure though..... go to home depot or autozone and get yourself a new intake and add a cone filter! what a perfect excuse to do a quick mod....
nice bumper by the way, you have good taste in armor...
Old 07-30-2010, 08:41 PM
j-money$$$'s Avatar
Thanks. The arb works great for me. I love it.
So as for a fix i took a bunch of grey rtv, and "glued" well I mean siliconed it back together. It is a custom silicon mounted air box now...... It flexes lol. I think i am going to scrape it off soon and epoxy it.
thanks all for the help
Old 08-24-2010, 04:38 PM
JBurt's Avatar
I just took off everything to clean my TB and cleaned everything else while I had it off. Found a crack in the same place. That mount behind the crack is the only good one left on mine (I guess that would put a lot of stress right there). I fabbed up some more mounts and I'm going to epoxy it back together. Shouldn't be a problem anymore.
Old 08-24-2010, 11:59 PM
wyoming9's Avatar
Red face
I used Gorilla tape to hold my air cleaner housing closed after the stupid clips broke.
i wonder how expensive a new box is??
Old 08-25-2010, 01:08 AM
Elton's Avatar
yep mine broke like that too all i did was cut some thin strips of metal a few screws and some blue sensor safe rtv let it dry and its been fine
Old 05-28-2022, 04:18 PM
Gatz101's Avatar
Need input on replaced air cleaner box
I purchased a used air cleaner box online that was supposed to be an exact fit but I think it’s for a 1994 helux. Mine is a 1992 Toyota pick up standard cab. The one that arrived has the whole cut out on the side instead of the front of the box. My guess is the helux Channels air from a different position on the truck. My question is does anyone know or have a suggestion on how to modify the box . I really don’t want to bore out another hole and cap the other hole to get it to fit. Also the old box has a plastic pipe inside the box and the helux one doesn’t. I don’t know if not using the pipe would effect the intake or sensors. Anyway input would be appreciated.
Doug4320
03-24-2018 10:11 PM
A2theK
07-12-2015 10:46 AM
Rkellerman
07-12-2015 08:42 AM
Poncho0206
07-10-2015 06:21 PM
horunner1x
07-10-2015 06:33 AM
Quick Reply: Cracked air box. Fixing ideas
