Comments on ISR mod...
Old 04-26-2005, 11:50 AM
rimpainter.com's Avatar
CJ-
I am talking about these two lines, but mainly the top one:
The top one goes to the Fuel Pressure Regulator, and we have found that this can cause the engine to run overly rich when plugged - which means it does have an effect on A/F ratio, albeit a small one.
So what did you do with those lines?
I can see from the other guys website that you are speaking of the crankcase ventilation hoses in your previous posts.
Old 04-26-2005, 11:57 AM
Tacoclimber's Avatar
Is it possible that my 03 3.4 and your engine is different? I'm just wondering. I think that what I was calling vacuum lines are, in fact the PCV return hoses. In that case, it changes everything, and I feel like a knucklehead.
Old 04-26-2005, 12:15 PM
Yeah, some 3.4L motors varied slightly. But as far as I know, they all retained the FPR line hook-up. Why don't you post a pic of your current set-up when you get a second. I would like to see how you routed everything.
We found that capping the FPR off completely caused a rich condition and slightly worse performance (at least that was my finding). I went back to hooking it up to the front silencer plug location. As soon as I get this SC'r put on I won't have to worry about that anymore though.
Old 04-26-2005, 12:19 PM
Ok, I'll get a pic and try to post it.
Old 04-26-2005, 12:24 PM
  #25
Hawaiian4R's Avatar
Originally Posted by SC4Runner
Id just throw this in here, but, last week I went to my "Yoda", who is a specialist for Toyota trucks. He owns his own garage here, and is realllllllly knowlageable for all years of Toyotas.
Anyways, I was talking to him about the ISR mod and he said that I should put back my boxes. He made a good point about Toyota spending lots of money in technology to develop a good intake system, and why the boxes were there in the first place.
Basically you have waves of air-flow to your engine. The boxes basically take the waves and smooth them out, and thus create a smoother engine.
Of course this is just one persons opinion.
My opinion is that its was cool and stuff, but, I dont know if I noticed any power gains or sound difference. The one thing I noticed is the LOUD WHISTLE noise when cruising.
Im most likely oging to take it out, but, im too interested other things right now
Hey SC4Runner, have you ever asked your friend what he thinks of the elbow removal mod?
Old 04-26-2005, 12:34 PM
  #26
Can anybody give me a quick rundown of how to post pics?
Old 04-26-2005, 12:59 PM
  #27
Here's one shot of the engine bay.
You can see both breather filters installed on the return lines.
That's pretty much the drill...
Old 04-26-2005, 01:03 PM
  #28
Lets try that again:
[IMG][/IMG]
And another:
[IMG][/IMG]
Old 04-26-2005, 01:30 PM
  #29
CJ-
I don't see the FPR line in those pics. Where could it be?
Old 04-26-2005, 01:51 PM
  #30
Christian, I think I found it. It is on the right side of the engine, nowhere near the intake hose. ? Different design, I suppose. There is a brass pipe that runs under the intake plenum. On the front side, the hose (originally) attached to it runs to the silencer box. On the rear, the hose attached to it runs to what I believe is the PCV valve, or at least part of the system.
Old 04-26-2005, 01:58 PM
  #31
midiwall's Avatar
Originally Posted by <96 Runner>
Hey Mark, how much do you know about this line? I knew it went down to the PS and had something to do with it, but I was never sure exactly what. In summary?
I found out about it when a buddy looked at what I had done (I had T'd them together to one tap after re-routing my vacuum lines) and asked "so, is it harder to turn when it's cold?".
The bottom line is that it's a boost for the PS hydraulic pressure that's based on manifold vacuum. If you look at how the lines are, one side taps before the TB and the other taps in after. When the difference between the two is "at some point" then the PS pressure is kicked up a notch. I called it a "coldstart boost" 'cause it was explained to me that it will kick in when the engine's cold, but to me, it seems like it will kick in anytime the difference between the pre/post TB pressure is high enough - like when you floor it.
Old 04-26-2005, 02:05 PM
  #32
midiwall's Avatar
That sounds like it... (the brass pipe leads to a hose which attached to the FPR at the rear of the left fuel rail). The front side goes to the (now old) silencer so that the FPR will open more as the vacuum increases in the intake. That will allow more pressure at the rails and injectors, thus allowing a smoother flow of fuel into the engine.
fwiw, the PCV valve is in the top of the right side valve cover, near the front, you can see it in your 2nd pic. It's the blueish piece in the lower right corner with the hose coming off the top and running to the TB.
Old 05-17-2015, 03:03 AM
  #33
gtct10b's Avatar
I'm not sure what an ISR is tbh so I can't comment but it would be interesting to know
Longbed 90
10-19-2015 11:05 AM
JookUpVandetti
09-30-2015 08:58 AM
irv
09-29-2015 06:20 PM
JRB4Runner2015
09-20-2015 12:29 AM
Boomer8404
09-10-2015 09:01 AM
Quick Reply: Comments on ISR mod...
