Coil Over Lift Kit for 3rd gen Runner
Old 12-01-2013, 04:31 AM
YFZsandrider's Avatar
I'm just about to pull the trigger on ordering a lift kit for my '98 limited 4runner. I'm looking mainly at the Toytec Ultimate Coilover kit and the BOSS Coil over system.
Anyone have any experience with both, or good input on the difference between them. I plan on this being a daily driver rig, but also taken of road a couple times a month. I'll be running 285/70-17 Duratracs.
Any input on any other lifts I should consider?
Old 12-01-2013, 02:09 PM
KZN185W's Avatar
you might like to consider Icon Vehicle Dynamics:
http://wheelersoffroad.com/product-c...namics-205847/
Other brands:
http://wheelersoffroad.com/product-c...ension-437513/
Old 12-01-2013, 07:57 PM
Originally Posted by KZN185W
That's quite a bit more expensive that the Toytec kits I was looking at... worth the higher price tag?
Old 12-01-2013, 11:46 PM
KZN185W's Avatar
definitely worth it.
next choice would be the TRD Tundra/LC80 lift. ---> http://www.sonoransteel.com/index.ph...ndex&cPath=1_2
Old 12-02-2013, 01:59 AM
Sonoran kits are just pieced together spring and shock components, correct? How is that better than a Toytec coilover kit?
Old 12-02-2013, 04:36 AM
KZN185W's Avatar
Correct and most of the parts are Toyota parts. I'm not familiar with the toytec lift so i can't give comparison. but there are a lot of members of this forum as well as those from other forums that have the TRD Tundra/LC80 lift
Old 12-02-2013, 05:52 AM
Well ultimately I want something that is going to give me as much of road capability, while still driving about 90% of its miles on pavement. Cost isn't too much of an issue if the price is well worth the performance.
Is there a too thread that breaks down the differences between some of the lift options?
Any and all input is appreciated!
Old 12-02-2013, 07:23 AM
hilgeg's Avatar
Just my $.02 - we have one of each of the lifts you have mentioned in our local 4Runner group. I've ridden in each.
-The Icon is the best for soaking up bumps and jumps at high speed.
-The ToyTec (although is was the Ultimate, not the BOSS) is a great lift too. No complaints.
-However, my vote goes to Sonoran Steel. Great flex and by far the best on-road ride. (this is what I'm saving my nickles for)
Whatever you decide give us your full report once installed!
Old 12-03-2013, 02:56 PM
Can a Sonoran coil set flex better that coilovers?
Old 12-03-2013, 04:57 PM
KZN185W's Avatar
If you have the stock UCA then the flex (front) of the SS 1.2 won't match the complete IVD system because the the stock UCA and UBJ will limit the flex (front).
However, you can replace the stock UCA with an IVD UCA and still use the SS1.2. Then it should be able to match the flex (front) of the complete IVD system.
For the rear, the SS 1.2 has better flex than the IVD because the SS 1.2 has longer shocks and coils. BTW, IVD does not have rear coils for the VZN185L 4Runner. IVD recommends instead the OME coil which is shorter than the Toyota LC80 coils that are used on the SS1.2.
Old 12-04-2013, 06:05 PM
KZN185W's Avatar
The front shocks used in the toytec boss system is manufactured by toytec. I'm not saying it's not good but toytec is not a shock absorber company. it's more of a kit assembly company.
Sonoran also has the radflo shock coil-over kits.
AustinTaco
08-22-2022 10:45 AM
live4soccer7
09-03-2015 12:29 PM
bowhunter1640
07-06-2015 08:10 PM
rondogracing
07-05-2015 12:32 AM
Niameyrider
06-25-2015 05:50 AM
Quick Reply: Coil Over Lift Kit for 3rd gen Runner
