Clutch squeak
Old 09-21-2011, 06:59 AM
crazy0000's Avatar
Clutch squeak
I have a 96 Tacoma, and the clutch started squeaking recently so I replaced the clutch pedal bushings and greased everything but there is still a loud squeak coming from the footwell. I think it's the master cyl or the rubber sealing the shaft on the firewall. Anyone have this problem and fix it?
Old 09-21-2011, 08:13 AM
GV27's Avatar
There's a lot of things to squeak in the linkage I suppose.
Mine was squeaking last week. Crawled up under the dash and it was coming from the return spring (where the spring contacts the pedal arm). Sprayed it with WD-40.
Chris
Old 09-21-2011, 08:16 AM
crazy0000's Avatar
When I say greased, I mean everything I can grease on the inside of the truck was done so haha. Its very frustrating.
Old 09-21-2011, 08:23 AM
Nuthuts96's Avatar
Location: Shelburne, VT previous: Everett, WA; Bellingham, WA
Happy Reading!
https://www.yotatech.com/forums/f2/f...bushing-19137/
Old 09-21-2011, 08:31 AM
morena67's Avatar
Mine too, but it's an 86 model... I haven't replaced anything from the pedal...
but I've changed my clutch master and slave cylinder about a year ago OEM parts...
I've just sprayed the moving parts of the pedal the other day with motorcycle chain lube spray...It helps a little...
Old 09-21-2011, 08:38 AM
crazy0000's Avatar
Originally Posted by Nuthuts96
Thanks man but I already have a spring like that on my pedal, the PO must have done it. Still squeaks.
Old 09-21-2011, 10:17 AM
You are sure it is in the cabin? In my case it was in the clutch housing. The arm moved by the slave cylinder makes a noise in my case.
Old 09-21-2011, 10:56 AM
crazy0000's Avatar
It's definitely attached to the master Clutch cyl.. But it might be on the engine side of the firewall
Old 09-21-2014, 05:46 PM
3/4tontoyota's Avatar
how did you fix it?
May I ask how you ended up fixing it so the squeak would quit?
Thanks!
kawazx636
10-06-2021 03:03 PM
primordialbeast117
12-19-2015 12:23 PM
smilen724
13
11-08-2015 04:11 PM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
Quick Reply: Clutch squeak
