Clutch slave cyl. hydraulic line question
Old 11-07-2008, 04:21 PM
Jeff B. in Michigan's Avatar
Good day,
When removing the slave cylinder hydraulic line, I borked up the fitting so I need to replace it. The fitting looks different than a normal brake line so I want to confirm which type of line to use.
Does anyone know what type of hydraulic line the slave cylinder uses?
Thanks,
Jeff B
Old 11-07-2008, 04:24 PM
jason191918's Avatar
Looks like a bubble flare to me.
bubble flare.
double flare.
In either case, just take it to the parts store and say I need one of these yay long.
Old 11-07-2008, 04:32 PM
Thanks Jason... did you notice the strange shoulder on the threaded portion? That is what I am worried about... otherwise it does look like a bubble flare.
Thanks,
jb
bubble flare.
double flare.
Old 11-07-2008, 04:36 PM
Looks like a...
I just noticed your signature... nice compliment of sound system components. Which pioneer do you have? I am running the DEH-P4100 and it rocks...
Old 11-07-2008, 04:43 PM
BajaRunner's Avatar
long story, but, I've used a regular flare fitting on a bubble flare and its been fine.
The parts store will hook you up though.
Old 11-08-2008, 05:37 AM
Thanks! Too be honest I don't even know which one it is. I'll check though.
Old 11-08-2008, 06:04 AM
97ltd4x4's Avatar
A double flare will work just fine.threads are probably metric so make sure you match them up.also Use a tubing bender spring,you could be carefull and bent it w/o one,but they are very cheap....Also if you find the correct line flared,and fitted and its too long you could just use the spring and shorten the line by making a series of loops.
Something like this:found in the hardware store plumbing isle..I would guess 1/4-3/8 sized for pipe.
http://www.acehardwareoutlet.com/(q3...px?SKU=2027274
Old 11-08-2008, 08:52 AM
Perfect... Thanks.
I ended up getting 10" of 3/16 brake line and two fittings to convert to metric. This is what it ended up looking like (I just used a piece of PVC pipe to make the loops)
Old 11-08-2008, 12:21 PM
Looks good! As long as it doesn't leak it serves its purpose.
the1998sr5
15
07-14-2020 08:35 PM
09-04-2015 09:27 AM
Poppie51
07-23-2015 05:03 PM
HookahRoo
07-20-2015 07:06 PM
Poppie51
07-16-2015 06:16 PM
Quick Reply: Clutch slave cyl. hydraulic line question
