Clean AC Evaporator?
Old 07-11-2004, 09:38 AM
gwhayduke's Avatar
We took a 4 hour trip the other day and toward the end, the AC was getting less and less cool. The air never did get warm, but it was barely cool enough to keep us comfortable as the sun was going down. I switched the AC off and it continued to blow cool air for 10 0r 15 minutes. When we parked, I saw no leakage from the AC evaporator drip tube.
I think the drip tube is plugged and the evaporator froze up. I blew it out once we were in town and ran the AC on recirc only on the trip home. Everything functioned perfectly.
So I figured I'd take off the evaporator cover, clean the coils, make sure the tube was clear and try it this week. But I can't get the lower cover off the evap. I've removed all the screws in the interior...Is there something I'm missing?
Old 07-11-2004, 04:16 PM
tallboy's Avatar
Its going to cost$$$$$$$$$
I really don'tknow about the '95 but on first gen. you have to have to remove the low and high side connections on the evaporator in the engine comparment. Witch means you should have the system refrigerant reclamed and then remove it. Which is not that much $ they will get you when when you have it recharged. After all the mounting screws are out then and the high and low refregernt lines are removed the whole unit will slide out. Then the plastic case can be removed.
Greg
Old 07-11-2004, 04:50 PM
AverysDad's Avatar
its the same deal with my 95 as with the 1st gen...........if you suspect a blockage of the drain tube take a short peice of wire and gentlytry to clean out the tube from under the truck.............as long as you dont jam it in there as hard as you can you wont damage the evap core.
Old 07-11-2004, 07:39 PM
gwhayduke's Avatar
I blew it out with compressed air and it seemed to work fine afterwards. I may start carrying some compressed air...
Thanks for the advice guys!
MO transplant
04-23-2023 11:58 AM
Blamalam
03-12-2022 07:34 AM
jasonty
41
12-23-2018 01:00 PM
this_guy
07-31-2015 01:27 PM
jjrbus
07-27-2015 11:06 PM
Quick Reply: Clean AC Evaporator?
