clank! on compression - what is it?
Old 09-19-2007, 06:09 PM
MadCityRich's Avatar
Lately when I drive over a rough spot in the road (like an expansion crack or heave), I get a metallic clank. I disconnected the front swaybar and links, but it's still doing making the sound.
It only does this when on the driver's side. Not the passenger's side. Sounds a bit like it's coming from the rear/middle but it happens when the front wheel hits and when the rear wheel hits. I managed to make the sound when driving over a speed hump, too, though it took a little effort. This means it's really only when it's a short, sharp hit to the driver's side.
Any ideas on where to look?
Thanks much,
MadCityRich
Old 09-19-2007, 06:19 PM
algranger's Avatar
what do you drive?
Old 09-19-2007, 08:16 PM
toy_tek's Avatar
I'd start looking underneath.
Old 09-20-2007, 06:11 AM
Yep, underneath.
It's an '02 4Runner 4WD. Sorry for the lack of specificity.
I've been trying to track down this noise for some time and wouldn't normally ask a forum such an inane question. But I can't find anything obviously loose. I was hoping there might be a standard piece that gets wonky. I'm guessing there isn't.
MadCityRich
Old 09-20-2007, 06:29 AM
mjwalfredo's Avatar
Maybe the swaybar bushing where the bar mounts to the frame is split/missing? Sounds crazy but it happened to me. The swaybar was rattling in the mount and it sounded quite clanky.
Old 09-20-2007, 08:17 AM
toy_tek's Avatar
Yeah that last response was tongue in cheek but I think you figured that out. =)
Do you have aftermarket skidplates?
I would probably get a rubber mallet and just start tapping around the undercarriage and see what you find.
Exhaust, body mounts... just about anything.
kawazx636
10-06-2021 03:03 PM
live4soccer7
05-11-2016 06:52 PM
Kamaloha
10-16-2015 05:13 PM
alexcarey
10-14-2015 06:05 PM
dzldust
7
10-06-2015 05:39 AM
Quick Reply: clank! on compression - what is it?
