Cheap trick by removing an acessory
Old 06-18-2005, 06:48 PM
fo_runner's Avatar
There might have been a thread about this, but i'll just show it to let everyone know.
If you happen to have pedal covers that go over the existing gas pedal, remove it. The brackets that hold the pedal down to the OEM pedal, prevents the throttle body opening at WOT No wonder my throttle body was opened only 3 quaters of the way; with the pedal pushed all the way. It also helps to remove anything bunching behind the pedal, so the pedal has room to move freely.
I know it seems silly to WOT a 3.slow, but at least you get "some" performance gain
Old 06-18-2005, 09:41 PM
Tacoma Dude's Avatar
There are some versions of this out there. Seems like the best way is to tighten up the slack on the throttle cable so you'll have WOT at full pedal depression.
Old 06-19-2005, 07:10 PM
fo_runner's Avatar
I tightened up the throttle cable, since there was slack in it. And yes there was a noticeable increase in throttle response and acceleration.
Old 06-20-2005, 09:43 AM
Flamedx4's Avatar
Yep, I experienced the same thing with pedal covers. I removed them too.
Old 06-20-2005, 09:50 AM
X-AWDriver's Avatar
Those pedal covers were probably getting you better MPG.
Old 06-20-2005, 08:23 PM
86runner's Avatar
i may seem stupid for asking but i am just a dumb ol' teenager... what is WOT?
Old 06-20-2005, 08:38 PM
CoedNaked's Avatar
Wide Open Throttle - IE pushing the "gas" peddle all the way down.
Old 06-20-2005, 09:38 PM
86runner's Avatar
gotcha, thanx
Old 06-21-2005, 06:57 AM
fo_runner's Avatar
It may give you good mileage, but we want all the performance potential from our engines (cough, 3.slow, cough)
Old 06-22-2005, 09:18 AM
Flamedx4's Avatar
An important attribute of Full Goose Bozo...
Old 06-22-2005, 10:14 AM
ish
ish's Avatar
i don't think i have ever gone WOT on my 4runner
Old 06-22-2005, 10:39 AM
4x4runner4x4's Avatar
i have to go WOT to get up hills on my 91 runner with 3.0. Havent done anything to it, i think ill try tightening the throttle cable which looks like should help a little. Is it an easy thing to do?
Old 06-22-2005, 05:00 PM
fo_runner's Avatar
Adjusting the throttle cable is very simple; all the tools you'll need are just a 12mm open-end wrench, and some penetrating lube just in case the 2 bolts are stuck.
You should try cleaning your throttle body too, or did you alredy do it?
Old 06-24-2005, 03:36 PM
no i havent cleaned the throttle body yet. what stuff do i use for that? or just a clean rag and wipe it down or somethin?
Old 06-24-2005, 09:37 PM
fo_runner's Avatar
For a complete write-up on throttle-body cleaning, go to:
https://www.yotatech.com/~corey/tech...b/haveblue.htm
Old 06-24-2005, 11:49 PM
alright thanks. my throttle cable still has a little slack to it. how can i tighten it?
Old 06-25-2005, 05:26 AM
Beartracker's Avatar
You will see the two adjusting nuts to get rid of the slack. Just dont go to far or you will have your idle way to high.If you let the engine warm up and have it running while you adjust it you will be able to tell when your raising the idle to much.
For me it would not make any sense to remove the peddle covers because I have never had to floor my 2.7 to pass anyone or climb any of these mountains. Can't afford the gas it would suck up every time I did that anyway,Lol. Mike
okamikai
04-30-2018 10:19 PM
alimant100
01-20-2016 05:58 PM
Jcrawl94
10
10-24-2015 04:34 PM
accuracy
08-06-2015 12:32 PM
TJWilly
07-31-2015 02:05 PM
Quick Reply: Cheap trick by removing an acessory
