changing antifreeze
Old 02-22-2011, 12:20 PM
ugabulldog's Avatar
changing antifreeze
i am looking in my Haynes manual and it says to remove the radiator drain plug and an engine block drain plug...... I don't remember removing the engine block drain plug last time..... is this needed and if so where is it??? thanks
Old 02-22-2011, 12:28 PM
justin_4runner's Avatar
its not really needed to remove it, if u pull the theromstat it will drain most of the water out of the block. or just leave it and refill.
Old 02-23-2011, 07:24 PM
skjos's Avatar
This picture was taken from the passenger side wheel well, it shows the block drain port, the drain bolt is right above it. Install some tubing on the drain port, route it into a bucket, then turn the drain bolt until the coolant flows out the tubing.
Picture with the tube installed on the port with the drain bolt above it.
Old 02-25-2011, 04:09 PM
Ron Helmuth's Avatar
very helpful photo skjos
appreciate that very much
Yotadawgjr
10
08-23-2015 10:51 AM
accuracy
08-04-2015 08:05 PM
krimsonone
07-29-2015 11:53 AM
kcaudill
07-20-2015 12:06 PM
Jonny246
07-12-2015 04:51 AM
Quick Reply: changing antifreeze
