CEL..Oxygen sensors ?
Old 08-09-2005, 08:21 PM
vltnolia@yahoo.com's Avatar
Well I just replaced all my spark plugs, cleaned the maf and o2 sensors with elec contact spray. Started up the car and everything was fine until i drove it like a half a mile down the street, then i saw the hidious cel come on. Is it the o2 sensors? If it is will i be able to just change one sensor or is replacing 2 a must?
thank you
Old 08-09-2005, 08:36 PM
Bob_98SR5's Avatar
get the code read and then google the cel # and figure it out from there. its not rocket science my friend!
bob
Old 08-09-2005, 08:39 PM
rimpainter.com's Avatar
...and you said sensor(s). I have never heard of both failing at the same time anyway. It will be bank 1 first - almost guaranteed. Get that code (Autozone will pull it for free).
Old 08-09-2005, 08:49 PM
i love it when you reply to my post, my friend!
Old 08-09-2005, 09:18 PM
Problem solved.. Ecu just needed to be reseted after cleaning of the o2 sensor.
Old 08-09-2005, 09:30 PM
Bob_98SR5's Avatar
i betcha it will be temporary. find someone w/ a code reader in the meantime
bob
Old 08-09-2005, 10:09 PM
good idea bob. I will do that just incase the cel will turn back on.
Randy
Old 08-10-2005, 09:28 AM
MTL_4runner's Avatar
bob
Ditto, cleaning the sensor will just prolong replacement for a few months.
Old 08-10-2005, 09:41 AM
LittleRedToyota's Avatar
what year is your truck?
if it is pre-95 (and, thus, OBD I instead of OBD II), you can easily pull the codes yourself using a paperclip or short piece of wire.
http://www.off-road.com/toyota/tech/codes/index.html
moparbay
03-10-2023 03:50 PM
jb451
7
10-07-2022 06:58 AM
Kreedy1
09-08-2015 06:33 PM
zz_denis
09-06-2015 03:43 PM
moparbay
09-03-2015 12:48 PM
Quick Reply: CEL..Oxygen sensors ?
