CEL again. Code P0446.
Old 06-15-2011, 11:03 AM
  #61
stir_fry_boy's Avatar
On my 02' I had to replace the canister. I had the P0446. Replaced the valve, came up with a P0440 and P0442 (small and big leak), replaced the gas cap and the leak codes were still coming on. Took it to Toyota and after 1.5 days they couldn't find a vacuum leak. They didn't charge me anything, but suggested a canister for $450 + labor! They also told me that they usually never go bad UNLESS you keep overfilling your gas tank. I bought the truck with this problem so I am positive that the previous owner kept overfilling it. When the pump clicks, STOP! Same as Rock Slide, I was able to find one off Car-Part.com for $50 shipped from NC to UT. It came off an 02' with 55K. Not one code since. When the dealer says "these never go bad" that is when I start looking at junkyards. Good thing they say that a lot about these 3rd Gen 4Runners.
Old 07-11-2011, 07:53 AM
  #62
lee1022's Avatar
U have to drop the charcoal canister that is under your spare tire on a 2001 4Runner. This canister has 4 bolts the 4th one is kinda hidden. U will have to disconnect your hoses 1st and your 2 electric connecters. Than there is another line connected on top U have to disconnect after U drop canister. Make sure U are prepared to do self taping on some of the rusty bolt that hold the canister up. Before U do any of this make sure your negative battery terminal is disconnected. P.S. I sprayed bust a nut on my bolts but 2 of them still snapped had to file, punch and drill and put self tapers in.
Old 07-15-2011, 08:44 PM
  #63
xcmountain80's Avatar
Guys I need some part number referencing will the part # 77740-08042 fit my 02 4Runner. This site http://www.findonefindall.com/toyota...evap_P0446.htm seems to show the same charcoal canister and vsv as I have even though its on a Van.
Thanks
Aaron
Old 08-08-2011, 10:24 PM
  #64
Just emailed a ton of junk yards that were listed as having the fuel tank.
A
Old 09-15-2011, 08:09 AM
  #65
I'm having a hard time sourcing a Vapor Canister from a 99-02 with less than 150k for less than $100.
A
Old 09-19-2011, 02:45 AM
  #66
lee1022's Avatar
U do not need 2 buy a Vapor canister
A
I changed the switch on top of the canister and had the O Ring replaced on canister. Have a honest mechanic do a smoke test on the canister. That is how U can see if it leaks. I know there are very few honest mechanics, so just tell them U want a smoke test to see if canister is leaking. If it is I'll bet it is the O ring on the canister. This can be a real pain to change but with patience U can
Old 09-21-2011, 08:24 PM
  #67
I changed the VSV valve switch or whatever with no positive results, which O- ring are you referring to? I believe there is just one larger node or vacuum pack attached to the front end of the canister, I saw it and made sure to keep it intact and re-lubed it with silicone before re-installation.
A
Old 09-23-2011, 06:41 AM
  #68
lee1022's Avatar
A
If U have the vehicle smoked tested U will see were it is leaking. I had this done 4 free by a good friend. When he put the smoke tester on it he saw right away were the leak was coming from on the canister. It was the O-Ring on the canister which he changed. I had to put almost a 1000 miles on it to get the two monitors off before inspection. Since than I have been driving with no problems over 2500 miles and still working great. I think people are making a mistake when they buy the whole canister. He informed me the O-Rings get dry rotted and that it was good that I changed the VSV switch anyway.
Old 09-23-2011, 01:00 PM
  #69
Lee1022, that seems like a reasonable thing to do. You wouldn't happen to know which line he used to pipe the smoke in would you, or would you happen to know whether or not the valves stay open or shut when the vehicle is off? Any additional info would be helpful, thank you again
A
Old 12-20-2011, 05:04 PM
  #70
KenAZBoat's Avatar
PO446: Diagnosed to be gas tank rollover valve
I have read all threads on PO446. I took in my 2000 4Runner into dealer today and paid to have it diagnosed. This error code has been intermittent for 2 yrs. It only has one error code, PO446. They said everything is OK but they are 90% confident that the gas tank rollover value is leaking. It will cost $15 for parts and $500 for labor.
No one has ever written about a gas tank rollover valve. Could this really fix it?
Old 12-29-2011, 02:06 PM
  #71
My first question is what thehell is a roll over valve and where do I get one?
A
Old 01-01-2012, 12:57 PM
  #72
KenAZBoat's Avatar
It is the valve on the gas tank that shuts off the gas tank vent if the truck rollovers. I had never heard of it either.
Old 01-05-2012, 06:21 PM
  #73
Don't happen to have a toyota part # do you?
A
Old 01-05-2012, 08:10 PM
  #74
TheDurk's Avatar
A
Looks like it's this one:
Toyota Part: VALVE ASSY, FUEL CUT Part NO.: 77380-26010
Old 01-27-2012, 04:07 PM
  #75
I'd hate to drop the tank and replace this and it not be the problem. SOmewhere someone mentioned the O-rings on the vapor canister being the source of the problem. Wonder if you could just use RTV instead.
A
Old 01-31-2012, 05:23 PM
  #76
Old 10-14-2012, 03:40 PM
  #77
lisk135's Avatar
I have a 1999 4Runner V6 2wd and I just received the code P0446. I used to get a really bad fuel odor in the summer if I topped off, so I would just fill half a tank and it would keep the vapor pressure down, and my canister would not stink as bad; no CEL though. No that the weather is cooling down, I got a CEL, and when I checked it I got the code P0446. I checked my Hayes book but it is not very specific when it came to EVAP. Not sure if its the charcoal canister, the little vacuum sensor that travels over to another sensor through a tiny hose, or the sensor valve that travels to the top of my engine through a normal sized hose. I am told it could be the gas cap, one of those three sensors outside of my canister (all three have an electrical connection), or the canister itself. The canister seems to have valves inside of it too. Its a box shape with two cylinders on it with 6 hoses going in and out to many things. Everything is right there under my hood and accessible right behind the battery. What should I do... I refuse to take it to the stealership. I can fixed any thing on my vehicle with my Hayes book, but this one thing.
Old 10-23-2012, 05:52 PM
  #78
luxdlx's Avatar
I replaced the VSV and gas cap with no luck. Anyone ever figure out where this o ring is?
4.34runner88
02-07-2016 02:24 AM
sanctfy
09-13-2015 06:33 PM
AkitaDog
09-03-2015 09:01 PM
Scatterbrain
09-03-2015 06:46 PM
moparbay
09-03-2015 12:48 PM
Quick Reply: CEL again. Code P0446.
