catastrophic transmission failure
Originally Posted by RTdawgs
How did you nuke a 2001 tranny?
Call Marlin at www.marlincrawler.com he rebuilds trannys.
#26
#27
Originally Posted by bamachem
they didn't have a 5-speed in 2001, and therefore your ECU wouldn't be compatable since it has all the traction control bells and whistles...
#28
Originally Posted by naksukow
Yep. So far I have been quoted $750-$1500 from online searches. I am still looking though and want/need all input.
thanks
thanks
#33
I found some available but nothing that I wanted to go with. The tranny is at IPT being rebuilt as I type this.
Let us know how it works out once you get it all back together.
#35
Worked great for about 65,000 miles, then the planetary gear "went" again. I posted it up on UY. I think heat may have killed it this time.
It was the full rebuild, so I think around $2700-$2800.
#38
I am guessing heat. I only ran Amsoil sythetic. I remember the last time I drained the fluid it was red and still clean. After the transmission problems the fluid color was a very dark metallic purple.
Instead of getting this one rebuilt, I got a reman one from an 04 core. These ones according to my tranny guy should have the "fix." So hopefully no more planetary gear problems.
I have a 3year/100,000 mile warranty on this one and I hope I don't have to use it.
I think I cooked it while offroading at Big Bear. I did Gold Mtn + John Bull back to back with 5 people in the car. I remember smelling burnt fluid on John Bull.
#39
i am assuming its a auto? well that sucks dude, autos are WAY more expensive to replace id go to a wrecking yard pull a used one with low miles if you cant afford to have it rebuilt.
#40
irv
10-01-2015 09:49 PM
ToyotaMD
09-22-2015 06:28 AM
FS[NorAtl]: FS: NYC 1987 4x4 22RE Engine and Auto Trans
TransAmBandit
09-20-2015 06:08 PM
kelly1450
09-02-2015 12:29 PM
a340, a340f, boost, carnage, catastrophic, failure, front, ipt, logic, rebuild, skid, trail, transmaster, transmission, vs
