BudBuilt Installation Questions HELP ASAP!
Old 11-14-2008, 04:55 PM
SWPERIC's Avatar
so when i ordered my skid and belly plates from bud, he joked about the slightly cryptic installation guide. Well its so cryptic that it must b invisible! im sure it was an honest mistake. now its friday night and im trying to install this beast.
I got the belly plate on when i realized i needed to remove the factory tranfer case "skid" that looks more like tin foil. i see where all the bolts go and they all line up but im trying to figure out if the belly plate goes on first and the skid plate attaches to the bottom of it. this would make sense to me because the skid has to come off for oil changes and the like. but now i need a bolted on right angle piece with 2 holes in it. it looks like they fit over the axle mounts??? im not sure if that is what these bolts r called.
anyway its back to the garage to play with it some more. any help would be greatly appreciated.
Old 11-14-2008, 05:56 PM
SWPERIC's Avatar
arg... bump
Old 11-14-2008, 05:58 PM
crolison's Avatar
I believe you can do either of the skids first, I would make sure the bellyskid is above the regular skid. So when you go over rocks it doesn't get cought while your going forward. Its just a simple bolt on procedure, you don't have to take the skid off to change oil it has a drain hole in it.
For the front skid you just unbolt your factory two piece and, then take the two bolts off of the steering rack, and attach the angular mount then bolt it all together to the stock holes.
I installed my budbuilt the other day, its not bad of a 1 man job if you use your bottle jack to prop it up.
Old 11-14-2008, 08:00 PM
SWPERIC's Avatar
aaah! i get it now. how do u secure the angular mount? i did not see any new hardware for that. thanks alot
Old 11-14-2008, 09:23 PM
wormhole's Avatar
You have the three front bolts, the two in the middle and the two in the back that bolt to the steering rack (the two holes right before it bends up towards the back, about 3/4" high), then you have the two holes to attach to the belly skid.
Hope that helps.
Old 11-15-2008, 04:02 AM
crolison's Avatar
I believe its a 21mm (maybe 22) and a 19mm bolt that are on the bottom of the steering rack, take those two off slide on the angular piece and bolt it on.
tj884Rdlx
08-28-2015 12:04 PM
Poppie51
07-23-2015 05:03 PM
rushw
07-18-2015 01:46 PM
Poppie51
07-16-2015 06:16 PM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: BudBuilt Installation Questions HELP ASAP!
