Bud Built Clocking Adapter?
Old 04-05-2006, 11:07 PM
914runner's Avatar
Hey all, I was wondering if the Bud Built clocking adapter will work on my '98 4Runner V6 5-speed?
I assume it would because arent the tranny and T-cases the same between the 4Runners and Tacos?
Thanks
Old 04-05-2006, 11:28 PM
BajaRunner's Avatar
I'd say it would fit... You should email them and make sure.
Old 04-06-2006, 12:31 AM
914runner's Avatar
I will probably do that unless someone chimes in and says they know it fits. lol
For $170, you cant beat that extra ground clearence.
Old 04-06-2006, 06:15 PM
BruceTS's Avatar
Yes they will fit, I have one sitting here ready to install.......
Old 04-06-2006, 06:18 PM
garrett1478's Avatar
didn't you say that in october?
Old 04-06-2006, 10:38 PM
914runner's Avatar
Well let me know how the install goes.
I think Ill probably pick one up.
Old 04-06-2006, 10:42 PM
i've been thinking about this too...hmmmmmm
bruce, what all is involved in installing this? how will it work with your dual cases? or will it not even affect your tcases?
Old 04-06-2006, 11:38 PM
...and how about some opinions on the FROR clockable crossmember?
http://frontrangeoffroadfab.com/nfos...8fd3801b7e27a7
clocking adapter and crossmember in 1. hmmm....
Old 04-07-2006, 02:20 AM
914runner's Avatar
It looks like you would still need the adapter with that. But that will give you alot more clearence too since you wont have the stock bulky crossmember in there.
Old 04-07-2006, 08:21 AM
AK95Taco's Avatar
The last time I looked into those the shifter/linkage was still being worked out. Has that been solved? If so how?
Old 04-07-2006, 08:32 AM
JGM
JGM's Avatar
There is some additional work required at install since the shifters will "clock" as well. Bud told me that this probably also requires at least a 1" BL.
Old 04-07-2006, 12:41 PM
914runner's Avatar
I was under my friends Double Cab Taco yesterday, and atleast on his, the fuel filter would need relocated, and a 1" BL too most likely.
I had already thought about the shifters, but Marlin can make you a new shifter bent for however much you clocked your case.
Old 04-07-2006, 12:46 PM
yeah, i read somewhere on TTORA that you can send your shifters to budbuilt and he will modify them for you.
Old 04-07-2006, 03:16 PM
AK95Taco's Avatar
I wonder if you could get them legthened too between the body lift and the clocking you wouldn't be left with much length... I have a 2" BL now and wouldn't want it any shorter than it is.
Old 04-07-2006, 03:39 PM
4crawler sells adapters which screw onto the top of the sticks to lengthen the stick after body lifts. i would give you a link, but it seems that half of his body lift page is missing.
Old 04-08-2006, 05:38 AM
dragr1's Avatar
Does he have a skidplate that would accomodate that crossmember?
ashamsuddin
17
01-13-2023 03:17 AM
hiluxinargentina
09-30-2015 05:51 PM
Cycles
09-29-2015 06:37 AM
Toys4parts
09-26-2015 01:56 PM
Quick Reply: Bud Built Clocking Adapter?
