Broke Swaybar connect Bald Mtn. (pics)
Old 08-04-2003, 05:41 PM
cvlighthouse's Avatar
http://community.webshots.com/script...ecurity=ZDozsA
http://community.webshots.com/script...ecurity=RbYQgD
Hey guys,
It's been awhile since I have posted.
To tell the truth, I've been spending to much time on the new motorcycle...
Anyway, I hope everyone is still wheelin....
I broke the stock swaybar connect at Bald Mt. Must have been when I droped 3 feet in the middle of the night. Yes, it was on purpose. What do you guys think I should do?
Should I replace stock?
Should I buy custom swaybar disconnects?
Should I just remove the swaybar?
The other picture was taken at Brewers Lake! Awesome fishing spot!
Old 08-04-2003, 06:18 PM
Cebby's Avatar
Links don't work for us. "You are not the owner of this album"
Old 08-04-2003, 07:21 PM
Plays_with_Toys's Avatar
You have to make those albums "Public." Or if you are looking at the pics in your album, click on "preview in community" and then give us that link.
Old 08-04-2003, 09:25 PM
seafarinman's Avatar
I have a set of aftermarket swaybar discos. They are a PITA to install the pins after use, so I simply removed the whole damn swaybar since the ride was not much worse than with the bar. Offroad manners makes it worthwhile.
Old 08-05-2003, 05:40 AM
ssbogger's Avatar
Here ya go:
Broken swaybar deal
Cool fishin' spot
Old 08-05-2003, 06:29 AM
AznSky's Avatar
I bought lars custom discos and I'm pretty satisfied with those. Taking them off was pretty easy, but putting them back on I had to have somebody pull the swaybar up because it was too low. Still, I'd reccommend them.
Old 08-05-2003, 08:04 AM
sbogger-
Thanks for fixin my links! I did a preview of the post and it seemed to work ok...
What ever happened to monty pics?
toyo 96- Lars custom discos? sounds pretty good. Where dod you get them?
thanks
Old 08-05-2003, 08:16 AM
turboale's Avatar
When you remove the sway bars, which one is more bennificial. I would imagine the rears give a bigger advantage since the ifs is the big limitation in the front right? Also, wouldn't it make more of a difference in on road manners if you take the front off since that is where all the weight is? Or do you guys just take them both off?
Thanks,
Old 08-05-2003, 09:35 AM
AznSky's Avatar
Lars discos
Actually some tests have been done and it's the general consensus that disconnecting the front swaybar helps you a lot, and disconnecting the rear doesn't really help you much.
Also you wouldn't want to pull out the swaybar if you plan on driving in the city or on regular roads, bodyroll will be a huge problem.
Old 08-05-2003, 01:52 PM
Darren's Avatar
I can't say I know of any other 3rd Gen owners who drive without the front sway bar connected. I have for probably a little over 2 months now by virtue of troubleshooting a clunking type noise. My bar was hitting something as having it disconnected was noise free. I had replaced one bushing and the other is fine. At any rate, there is quite a bit more body roll on cornering. Taking it down mountain grades and such, you have to definitely be slowed down more. My ride also softened up considerably. It's definitely manageable though.
I have Lars' discos as well, but haven't used them. I've tried them out in the driveway and have found them real tough to disconnect from the bar. I currently have my sway bar on, but have removed the disconnects. I'll probably try them out again at some point. I just wish they'd slide right off. I'm probably doing something wrong though.
oldirtydirt
02-23-2020 09:30 AM
okamikai
04-30-2018 10:19 PM
edoyle12
11
03-20-2017 02:26 AM
theking11863
03-19-2016 09:36 PM
Poppie51
07-23-2015 05:03 PM
Quick Reply: Broke Swaybar connect Bald Mtn. (pics)
