Brake Light on Dash Intermittant
Old 12-27-2012, 08:54 PM
Gregs94Toy's Avatar
Question Brake Light on Dash Intermittant
Under heavy acceleration at times, the e-brake light on the dash comes on for a few seconds then goes out after the initial speed is slowed down...any reason for this? Handle works properly and works fine...
Old 12-27-2012, 09:11 PM
Discombobulated's Avatar
Fluid level, had the same issue upon start up and on hills filled to the line and it went away.
Old 12-27-2012, 09:12 PM
Gregs94Toy's Avatar
LOL duh! I should have thought...thank you very much!
Old 12-27-2012, 09:37 PM
Greg_Canada's Avatar
Your brake pads probably need to be changed... the fluid gets low because the pads wear out. Give them a check. They could still have 50% life left tho... better safe than sorry to check..
Old 12-27-2012, 09:44 PM
Gregs94Toy's Avatar
I just remembered I had bled the brakes about 2 months ago and never really refilled the reservoir....yeah that's it...Pads look fine...
Old 01-01-2013, 08:41 AM
X88&94GT's Avatar
Mine did that when I bought it and I used it to negotiate down. Kept happening, ended up being a slow leak in a soft brake line. Finally got bad enough to be able to see it.
ashersullivan88yota
01-18-2022 05:37 PM
jasonty
41
12-23-2018 01:00 PM
fountain
12-31-2015 06:08 AM
Sandman
07-14-2015 12:36 PM
Johntom240
7
07-13-2015 12:18 AM
Quick Reply: Brake Light on Dash Intermittant
