Old 03-30-2016, 03:30 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Towing & Hauling Guides
Print Wikipost
Brake Controller & 7-pin trailer Install 3rd Gen 4Runner
Old 01-04-2008, 09:49 AM
ajsamora's Avatar
I recently installed a brake controller and wiring harness in my 1997 4Runner. I decided to take some photos and create a "How to".
Parts
Old 01-04-2008, 10:02 AM
pkt1213's Avatar
Man. This was exactly what I was looking for. I am going to have to put one of these in and I have never really messed with trailer brakes before besides air brakes.
You rock
Old 01-04-2008, 10:14 AM
Rock Slide's Avatar
Wow, what a way to make an intro here at YT! Great write up and detailed pics
Let me just add this - Be sure to seal up that hole in the firewall really good. I ran some wires like that too in my 4Runner and thought I had it sealed properly until I discovered water was leaking into the cab thru that hole when it rained. I'm sure you sealed it properly, just wanted to make sure others knew to do so.
Again, nice work
Old 01-04-2008, 10:18 AM
ajsamora's Avatar
FYI on the parts:
Dexter axle Predator Controller: $60.00 Shipped http://www.dexteraxle.com/predator_dx2_brake_controller
Napa
30 Amp Circuit Breaker Fuse $8.00
15' 12g Black Primary Wire $6.00
15' 12g Blue Primary Wire $6.00
12pc pack of Crimp Caps $3.00
Misc ring terminals $2.50
4 Self-tapping (Stainless or plated)screws $1.50
Pollack Trailer 7 pin connector with bracket $15.00
6' of 14ga 7-strand trailer wire $10.00
4 red wire nuts $2.00
4 zip ties $.50
Old 10-15-2010, 02:13 PM
SDMF's Avatar
Also you don't want the wires to chafe around the hole that was drilled. Maybe find a rubber grommet, snip it and pull the wires through and place in hole. That almost sounds a little nasty.
Nice write up! Just what I needed.
Old 07-31-2014, 06:24 PM
GoneGator's Avatar
Thanks a million for doing this! You just saved me time and money!! I hope good things happen to you.
Old 07-31-2014, 10:29 PM
wyoming9's Avatar
Red face
Wow you are my Hero so brave as to show pictures of wire nuts on stranded wire!!
Old 01-08-2017, 11:21 AM
One Sick Puppy's Avatar
Would like to thank you for this thread - it helped me alot.
I installed my brake controller (Tekonsha Primus IQ) above the fuse panel. I couldn't get an angle I was happy with on the other side of the steering wheel. I only had to cut a little bit of plastic out with a Dremel and cutting disk. Super easy. On the left side worked out even better. I can see and reach it easily while driving. Obviously, if you have switches above the fuse panel, like an e-locker, this won't work. I was going to mount it in the fuse panel area, but the door arm got in the way.
I'd suggest using 10AWG for the black wire, tho. Just for peace of mind. After looking around at controller installs, seems like this is best practice.
Wire wasn't as hard to find and splice into as I thought. I used a crimp-splicer thingy. Made things super easy.
Old 01-09-2017, 06:15 AM
83's Avatar
I put mine on the right side but it barely misses the e-brake (I have a Tacoma) and my knee. Someone with longer legs might be hitting it all the time. The one thing about a brake controller- they're always lit up. I got lucky in that a direct view of mine is blocked by the steering wheel. I need to move my head to the side to see it. Otherwise it would drive me crazy at night. I had to put electrical tape over the passenger airbag on/off indicator since it bothered me at night...
With a pickup there's less drilling into the body, which is nice. I'm pretty sure the only holes I put in my truck were for mounting the fuses. Everything else used existing holes or I just ran the wire outside the truck along the frame. The only splicing I did was into the brake light wire coming off the brake pedal.
Old 05-12-2017, 12:20 PM
NEKExplorer's Avatar
This is n awesome write up- Thank you very much. Only one part I am confused on- the Reverse (back up lights?) wire coming off the 7 blade plug (its a purple wire on my Hopkins adapter, wired to the center pin)- where do I attach that wire? What do I splice into?
Thanks for any help
Old 07-08-2017, 06:29 PM
magillaGG's Avatar
Pictures not working?
I'm researching this for a popup camper that has brakes. It's not possible to do brakes with 4-flat right?
I wish the pictures worked. Does anyone have the write up? Pictures?
Old 07-09-2017, 07:09 AM
83's Avatar
Yeah you'd need to upgrade. I mean in theory you can mickey mouse it and just run another wire for brakes, but that's almost as much work as switching to a 7 pin and a hassle.
What's your vehicle? There are probably other tutorials online. It's a lot more straightforward on pickups than 4Runners.
AustinTaco
08-22-2022 10:45 AM
marcusSRG
06-27-2015 07:13 AM
Niameyrider
06-25-2015 05:50 AM
infinityisfive
06-16-2015 06:51 PM
Gene
19
06-03-2002 07:07 PM
Quick Reply: Brake Controller & 7-pin trailer Install 3rd Gen 4Runner
