Bigger tires impact ABS?
Old 07-08-2003, 09:19 AM
sdrunner's Avatar
Do larger tires impact the ABS speed sensors? I switched tires from 225/75/R15 to 31x10.5 R15 on my 1997. I recently needed to make an emergency stop. Instead of the ABS kicking in, the wheels slid on the pavement.
Old 07-08-2003, 09:41 AM
Senior Member
jacksonpt's Avatar
I went from 29s to 32s and didn't notice anything... my ABS still kicks in like it always has.
Old 07-08-2003, 11:54 AM
Does your ABS dash light come on for a few seconds then go out after you turn ignition on? Might be your ABS system is not working.
Old 07-08-2003, 11:55 AM
Gbost's Avatar
I went from 31's to 33's and have had no problems.
Greg
Old 07-12-2003, 10:31 PM
colt ar's Avatar
my buddy was told from the dealer not to change wheel size or tire size because it would effect the abs,this was on a 2001 tacoma.I also heard guys were just disconnecting the abs when going with bigger wheel packages
Old 07-13-2003, 12:01 AM
Jeff the marmot's Avatar
Yes, larger than stock tires will affect ABS because the tire will decelerate at a different rate since it has more rotating inertia. So your ABS will be less sensitive to notice the onset of locking up a wheel(s), although ABS will still mostly work as long as you're only increasing a few inches in tire size.
09-04-2015 09:27 AM
94ofCanada
08-14-2015 06:37 AM
nickbeauregard
12
08-07-2015 06:04 AM
ty1er
08-01-2015 11:53 PM
Michael oaks
07-27-2015 11:47 AM
Quick Reply: Bigger tires impact ABS?
