Bigger tires on the back, possible problems?
Old 08-27-2007, 07:35 AM
irunner's Avatar
Hey guys,
Two of my tires have nails in them,they are 255/70/16. My dad has two extra tires that are 265/75/16, he told me to put the bigger tires on the back because eventually i want to upgrade to 265/75/16 all the way around. Would this cause any major problems? thanks
Old 08-27-2007, 07:41 AM
04 Rocko Taco's Avatar
dont run it in 4WD while they are different sizes, and you'll be fine.
you might be fine anyway. I run 265/75/16's in the rear and 265/70/16's in the front.
But I am only 2WD, so no issues for me.
Old 08-27-2007, 07:59 AM
colsoncj's Avatar
As long as you dont run it in 4wd you'll be fine. (speedo might be a little off though)
Old 08-27-2007, 08:24 AM
neliconcept's Avatar
taco or 4runner and what year is it, as others said, dont run in 4wd, but if you have an 01-02 4runner, dont even bother, VSC will give you its period on a stick.
Old 08-27-2007, 09:09 AM
irunner's Avatar
It'a 1997 4runner SR5 2wd.
Old 08-27-2007, 09:21 AM
go for it then for a while, but it may drive just a tiny bit odd.
Old 08-27-2007, 10:31 AM
dijlop's Avatar
it rly wont make much of a difference. been there done that. except even more so of a difference. i had 215/70/14's on the front and 245/70/15's on the back for a while. it was a little weird, but it was just like the rear was lifted a little higher than the front. pretty normal anyways right?
ive also driven with different treaded tires before. same deal. except one would spin on wet roads because it was a ht ,and the ohter was an at.
Old 08-27-2007, 11:11 AM
cackalak han's Avatar
Yeah, if it's a 2WD, don't sweat it.
Old 08-27-2007, 11:26 AM
engineerjoe's Avatar
speedo will be ~5% off (i.e. at 50 mph you'll actually be doing 52.5mph)
Old 08-27-2007, 11:28 AM
RustBucket's Avatar
And actually if you were on slippery/sandy ground you could put it in 4WD and it wouldn't really be a problem. Tires slip a bit in that terrain anyways.
vasinvictor
01-20-2016 12:39 PM
Ichneumon
09-27-2015 04:21 PM
rondogracing
07-05-2015 12:32 AM
renorunnerguy
3.4 Swaps
06-28-2015 09:18 AM
marcusSRG
06-27-2015 07:13 AM
Quick Reply: Bigger tires on the back, possible problems?
