B&M Tacoma 5-speed short shifter kit
Old 09-02-2004, 11:37 AM
SEAN_at_TLT's Avatar
B&M Tacoma/4Runner 5-speed short shifter kit
Just finished the write-up for the B&M Tacoma/4Runner short shifter kit, check it out HERE
I made a nifty little diagram showing how it works too...
Old 09-02-2004, 07:06 PM
Albuquerque Jim's Avatar
Can you recommend a place to buy one?
Old 09-02-2004, 07:12 PM
I don't know of any nationwide distibutors for B&M so try this place I found on Google...
http://www.martelbrothers.com/custom...at=1297&page=1
you might look around more and find a better deal though, not sure.
Old 09-02-2004, 08:06 PM
AzStorm's Avatar
Is there anything like this available for the 1991 22re 4x4??
Old 09-02-2004, 08:14 PM
To the best of my knowledge, these are only available for the Tacoma's. They do make it for both 2/4wd and 4/6 cyl though...
Old 09-02-2004, 08:16 PM
Come to think of it though, I think LC engineering makes one for the older trucks.
Old 09-02-2004, 08:57 PM
rixham's Avatar
Only for the Tacos.. Damn and I really wanted one for the Runner. Maybe some day. Hurst and or B&M need to make one for the Runners.
Old 09-02-2004, 09:03 PM
AzStorm's Avatar
Ive got a ton of LCE goodies in my truck.I'll check with them...Thanks!
Old 09-03-2004, 04:15 AM
I think the Taco and 4Runner share the same tranny, so it should work for us too!
Old 09-03-2004, 05:43 AM
Guest
jruz's Avatar
Cool, nice write-up. Now you just need to get the twin stick kit from Marlin and you'll have a whole new shifting setup.
Jim
Old 09-03-2004, 09:30 AM
You are correct, it will work for 3rd gen 5-speed 4Runners, they use the same tranny's as Taco's.
We plan to install a twin-stick in the red Taco eventually, probably once we install a crawl-box...
After driving with this B&M shifter, it makes me want to swap a 5-speed into my Runner! Auto's can get so boring...
Old 11-30-2004, 06:25 PM
jimbo74's Avatar
lce has a short shifter for an like 3rd gen pickups... but i didnt see one for the older 2wd like my 85
Old 11-30-2004, 06:29 PM
I think LC engineering has one for your truck jima.
Dredging up ooooold posts!
Old 11-30-2004, 06:48 PM
kyle_22r's Avatar
i know they all use the same shifter seat but i think the base of the shifter may be different between models. i wouldn't mind a short shifter for my truck
Old 11-30-2004, 06:59 PM
jimbo74's Avatar
oops. i meant to post in another one, i think this was linked off of it.... i went to lce site, they had one for later trucks but not the 85
Old 12-01-2004, 07:30 AM
heckler's Avatar
thats pretty cool, i never would have guessed that B&M made anything for toyotas.
I was thinking about the twin stick the other day and i came to the conclusion that it wouldnt be really worth it unless you had a locker in the front. Or am i wrong?
Old 12-01-2004, 08:36 AM
steelhead's Avatar
I have read lots of people that either liked them or had troubles with noises and such. What do you think of it so far?
Old 12-01-2004, 01:23 PM
dexter's Avatar
yea i started that other thread and cant decide on which one i want. the marin crawler one is cheaper but you have to send in your old shifter to be modified.
Old 12-01-2004, 04:26 PM
NorCalVP's Avatar
FYI MarlinCrawler also sells short throw shifters for most models. I know of a few that are in Taco's.
and i believe they are only $100
Steve
Old 12-01-2004, 08:28 PM
4Crawler's Avatar
Wondering if folks would be interested in the B&M style shifter for the '95 and earlier transmissions? I'm looking at making a kit similar to what I make for the transfer case shifter:
http://www.4Crawler.com/4x4/ForSale/...wShifter.shtml
for the transmission. Basically would start with the B&M Tacoma shift kit and then would use a different spacer plate to fit the different trannys. Would be looking at about $60-90 on top of the B&M shifter.
I've been running the short throw t-case shifter for over 6 years now with no problems at all. Its a very reliable system and has the benefit of being able to revert to stock and/o move it to another vehicle if desired.
Quick Reply: B&M Tacoma 5-speed short shifter kit
