Axle Oil Seals Keep Leaking
the seal can't be set in the pocket too deep or the seal won't ride on the spacer. Pull it out and get a new toyota seal and set it in 2-3mm less deep. Check it with grease before bolting it together.
rear-axle-seals-ultimate-information-replacement-thread-3rd-gen
Ughh... Since I don't have measuring tools like that, should I just, not put it in all the way, but close? then let it press itself in as far as needed when I bolt the shaft assembly back on?
jasonty
41
12-23-2018 01:00 PM
Iceman4193
07-15-2015 04:48 PM
