Automatic Gear Shifter won't come out of park without rocking the car
Old 08-24-2011, 07:12 PM
t-t-t-taylor's Avatar
Basically have to force it into drive. Rocking the car from behind with help. Currently have it parked in Neutral with parking break on.
Any Ideas?
99 4Runner 4-wheel drive
Old 08-27-2011, 02:41 PM
mynameistommy510's Avatar
This most likely has to do with the gear shift solenoid. When you press on the brake pedal, you should hear a click near the shifter. If not, The plastic cover around the shifter should come off. a large brown cable runs to the shifter. Check its connection. If all fails, i've heard of a shift override on the right portion of the shifter that can be depressed to shift no matter what.
Old 08-27-2011, 03:59 PM
KZN185W's Avatar
maybe the brake switch is dead? step on the brake pedal and ask someone to check if the brake lights light up.
Old 08-29-2011, 07:34 AM
CTRJ's Avatar
Neutral safety switch.
Charecter1
11-06-2023 10:08 AM
mskalmus
05-28-2017 07:51 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Automatic Gear Shifter won't come out of park without rocking the car
