ARB bumper installed
Old 10-02-2009, 10:25 AM
j-money$$$'s Avatar
Got my arb on a few day ago and i took a pic this morning. The install was easy, but i need to modify the mounting holes and slide the bumper up another 1/2 inch due to my body lift. it isnt too bad now, check it
Old 10-02-2009, 10:47 AM
nintythree4runner's Avatar
very nice. jsut need some sliders and rear bumper.Those Wheels would look sick in black to match the bumper.
Old 10-02-2009, 10:57 AM
Mauzer's Avatar
Which ARB is it? Tacoma?
Old 10-02-2009, 11:02 AM
j-money$$$'s Avatar
thanks, and i know the wheels would be sick black, but they are discontinued and were never offered in black
and yes it is a tacoma bumper. everything lines up and fits because the tacoma and 4runner have similar frames
Old 10-02-2009, 11:04 AM
Mauzer's Avatar
Nice, looks great!!
Old 10-02-2009, 11:11 AM
camo31_10.50's Avatar
spray paint them rims man!!!!
anything can come in whatever color you want it..you just have to make it!
just rough em up with som sand paper..tape of some spots to make em stand out (not just all black..leave some spots chrome) spray em down..
Old 10-02-2009, 12:52 PM
BajaRunner's Avatar
Looks nice and new!
How much body lift do you have on there? Remember you want about 1/2" gap anyways so it doesn't rub up against the body panels.
Old 10-02-2009, 02:30 PM
j-money$$$'s Avatar
i have a one inch bl. and i was gonna slide the bumper up 1/2 inch leaving a 1/2 inch gap, or close to it i actually have not measured the gap. fixing it will be a pain in the a**
Old 12-18-2009, 05:29 AM
A2B in a TLC's Avatar
ARB Bumper Installed
ARB says the frame rail end (1999 4Runner) should be reinforced with a welded plate. Has anyone done this? From my hours of research on this forum, it would appear that most are simply cutting off the flanges and mounting the brackets & bumper.
Please - if anyone has photos or a writeup on the frame rail reinforcement, please post.
Thanks,
Bruce in Tsawwassen
Old 12-18-2009, 06:12 AM
stock as possible's Avatar
Who'd you purchase from, and what did it set you back? Looks good!
Old 12-18-2009, 07:37 AM
Mtn Mike's Avatar
Looks great. I want one! Has anyone installed an ARB with stock suspension? Should I look into stronger springs first?
Old 12-18-2009, 09:03 AM
gpcollen1's Avatar
I do not think the bumper is all that heavy that you 'need' a suspension upgrade but it could never hurt. I have PP springs on mine and the ARB in the garage waiting to be powder coated and installed.
Old 12-18-2009, 09:13 AM
brian2sun's Avatar
hey looks good j-money$$$! We're almost twins! BTW, I shot my rims with flat black and like how they turned out.
Old 12-18-2009, 11:42 AM
brian2sun's Avatar
Thanks,
Bruce in Tsawwassen
http://www.nwtoys.com/tech/frame-endcap
Old 12-18-2009, 12:03 PM
Smile Thanks
You, sir, are a gentleman.
Thanks Brian. That is great. It's one thing to fit the bumper on. But if one plans to use a winch, this mod is important.
How's the weather down south?
Bruce in Tsawwassen, BC
Old 12-18-2009, 12:33 PM
stockwell45's Avatar
yeah i have the same problem with the ARB bumper and the one inch body lift. I would love to see a complete writeup step by step what to do
Old 12-18-2009, 12:51 PM
I figure the reason ARB DOES NOT provide complete instructions has to do with liability issues. The Taco bumper has not been officially tested - especially the airbag sensors - for the 4Runner. Even though everything will probably work just fine, if there is a problem and a complainant can point to ARB 4Runner install instructions..... oops.
ARB is a GREAT company. I have used their winch bumper, OME leafs, IPF lights, etc on my HJ60.
Bruce
brian2sun's Avatar
You're welcome Bruce. The weather down here is wonderful right now, but it was snowing last week. Looks like we might be in for a sunny Christmas this year.
BTW, I bolted my bumper on and then I welded the mounting brackets to the frame rails with 1" strips on the top, bottom, and both sides of each frame rail (where I could grind the welds if I ever wanted to remove the ARB). I think my method is easier and just as strong if not stronger than the "weld the L plate and bolt the bumper on" method.
Stockwell45, I haven't seen any actual write-ups, but these pics should help (courtesy of MillerPKA). You just need to cut the brackets and re-weld:
Old 12-18-2009, 09:22 PM
hey thanks brian. do you know if doing this will still allow the bumper to be strong enough for heavy winching?
Old 12-19-2009, 01:49 AM
brian2sun's Avatar
I would say no. This will just make it look better with the body lift. I think heavy winching would put too much leverage on the mounts IMO.
Quick Reply: ARB bumper installed
