Old 02-09-2016, 09:55 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior Guides
Print Wikipost
Anyone Know How to Replace Drivers Side Mirror
Old 03-31-2003, 06:56 AM
RandyM's Avatar
Hey all, does anyone know how to replace a drivers side mirror on a 2000 4Runner? Do I need to remove the tweeter and can get access from there or do I need to remove the door panel?
Thanks guys.
Old 03-31-2003, 07:57 AM
Hermes's Avatar
The plastic covering the tweeter just pops right off. Once that is off you should see three bolts that hold the mirror onto the door. You shouldn't have to remove the tweeter mount. However, I have only every loosened my mirror to install my ventshades.
Now I do know that when I had my driver mirror replaced they had to remove the door panel to replace the electrical connectors for the mirror.
Hope that helps.
Old 03-31-2003, 10:01 AM
Bob_98SR5's Avatar
Hey Randy,
Good to see you here. If you can wait until I get home tonite, I can send you a diagram via email or post it back here. Check back tomorrow morning.
I had to replace my wife's driver side power mirror on her 95 Camry. It was just a matter of popping off the cover, removing the power connector, removing three bolts, and re-attaching the new mirror.
By the way, the Xterra step tubes are holding up just fine. I get compliments (and sometimes puzzled looks) about twice a month.
Bob
Old 03-31-2003, 10:18 PM
Bob_98SR5's Avatar
Randy,
Here is a scanned page from a Chilton's manual. Its easy.
Bob
Old 04-01-2003, 09:49 AM
RandyM's Avatar
Thanks guys for you help. Sounds really simple to do. Bob, glad to hear that your steps are holding up...no problems with mine.
Randy
Old 10-21-2004, 07:33 AM
GregStevens's Avatar
Yep, this thread is as old as the hills. But I want to remove the side mirrors on my 92, but I don't see how to disconnection the connections for the power. Bob had a scanned image of the Chilton's manual, but the link is dead.
Removing the 3 screws is easy...do I have to take the door panels off to get to the power connections?
Any help would be appreciated...this is the only mirror removal thread I could find.
Thanks!
Old 10-21-2004, 08:16 AM
terryjmatthew's Avatar
Yes, Tou Do Have To Remove The Door Panels To Unplug The Mirror.
The Plug Should Be In About The Middle Of The Door!
Old 10-21-2004, 08:20 AM
OK, that's what I'll do...
I'll search to find how to remove the panels.
Thanks!
Old 09-18-2010, 07:46 PM
tatesrus's Avatar
The mounting tabs are broken on the power module for the driver-side power mirror on my 1994 SR5 pickup. I'd like to just replace the whole mirror - maybe passenger side too if I can find the right deal. After searching all over the internet though, I haven't found a source for replacement power mirrors. There does seem to be a lot of availability for replacements for 4Runners and T-100s though - both of which look very similar to the pickup mirrors. Anyone know if they're interchangeable? Thanks!
- Glynn
06-01-2021 01:51 PM
lledwod
08-30-2016 01:03 PM
msane99
07-11-2015 08:08 PM
colinmil
07-06-2015 04:03 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Anyone Know How to Replace Drivers Side Mirror
