Anyone have 3.42 gear ratio?
Old 10-08-2010, 05:30 AM
Nelsonmd's Avatar
Originally Posted by Csefiroth0
This is going to sound weird. I did as you guys said and jacked up the rear end, turned the right rear wheel one full revolution, and watched the driveshaft turn 1 3/4 times. I did it multiple times and kept getting 1 3/4 turns. I'm probably sounding dumb, but this correlates with a 1.75 gear ratio, which does not make sense.
Doing it this way can leave alot of room for error. Be sure you only jack 1 tire up like rock slide said, and then have someone spin the tire 20 times. Divide the number of drive shaft rotations by 10, and that should be your ratio (divide by 20 for the spins, and multiply by 2 because one tire is fixed).
The more times you spin the tire, the less error you introduce (unless you mis-count the rotations).
Old 10-08-2010, 01:21 PM
Csefiroth0's Avatar
Trust me... i did not screw it up. It turns 1 3/4 times.
Chris
Old 10-08-2010, 01:48 PM
Nelsonmd's Avatar
Chris
Ok, well you're the one with a 3.5 gear ratio... the only one...
Old 10-08-2010, 03:39 PM
Csefiroth0's Avatar
Or maybe i have 3.5 because i didn't divide by 2 and multiply by 20.
Old 10-08-2010, 03:50 PM
  #25
Nelsonmd's Avatar
Look man, I'm just trying to help. That was the way I was told by people here to check my gear ratio and it worked, and it makes sense by the mechanics.
By just spinning once, you have to tell the difference between 1.75 turns, or 1.86 (for a 3.72 ratio), or 1.71 turns for a 3.42 ratio. My point was that it is easier to count a couple extra rotations than try to discern a few degrees of rotation. But that's just me.
So how do you interpret the results of your test? What does 1 3/4 turns correspond to?
Old 10-08-2010, 04:18 PM
  #26
KZN185W's Avatar
you might also like to try www.toyodiy.com use your VIN to get the possible gear ratio to confirm your manual count
Old 10-08-2010, 04:34 PM
  #27
raydouble's Avatar
This is from car-part.com....if you are 2wd this is saying you have 3.73.....
(6 cyl w/ABS), 4x2 (3.73 ratio)
(6 cyl w/ABS), 4x4, 15" whl, 3.91 ratio
(6 cyl w/ABS), 4x4, 15" whl, 4.10 ratio
(6 cyl w/ABS), 4x4, 15" whl, 4.30 ratio
(6 cyl w/ABS), 4x4, 16" whl, 4.10 ratio
(6 cyl w/ABS), 4x4, 16" whl, 4.30 ratio
Old 10-15-2010, 01:39 PM
  #28
blcktpgsr's Avatar
On a side note...Not all 3rd Gen with Lockers have 4:30 gear ratio if basing on the axle code on the door jamb. This one reads A03A. Mine is Locked with A04A axle code...could it be because this truck has a manual tranny? Explain explain???
http://cgi.ebay.com/ebaymotors/Toyot...fCarsQ5fTrucks
Old 10-15-2010, 02:34 PM
  #29
JamesD's Avatar
So giving the VIN to the dealer is still a possibility to be wrong?
Old 10-17-2010, 07:13 PM
  #30
Rock Slide's Avatar
You got it
Old 10-22-2010, 03:07 AM
  #31
LINY4Runner's Avatar
while doing the e-locker swap, I gave a few turns on my old diff...it's 3.90's so raydouble's chart may be on point ^
Old 10-22-2010, 07:12 AM
  #32
Rock Slide's Avatar
Liny, that gear size sounds right for you 4Runner...probably why you're getting such low mpgs w/ those size tires & rims.
RatOmeter
10-22-2015 03:17 PM
norcal98
08-10-2015 06:20 AM
wolfpackfan33
08-02-2015 03:36 PM
Shaun Crystal Gomban
07-30-2015 10:13 PM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
Quick Reply: Anyone have 3.42 gear ratio?
