Any harm to the drivetrain by going with bigger tires?
Old 05-03-2010, 09:23 PM
Rspct2All's Avatar
I might have over-exaggerated the title, but what I meant was:
Current tire size on my 4Runner, 265x70xR16 Yokohama Geolander H/T-S G051.
Possible considering, 255x70xR16 Yokohama Geolander H/T-S G051.
Any advantages or disadvantages between such a comparison?
Thanks!
Old 05-03-2010, 10:31 PM
jcknthegrn's Avatar
By bigger do you mean wider? The OD of your current tire is 30.6" and the tire you are considering has an OD of 30" and is marginally wider. The diameter difference is only 2% which means your speedometer will read 2% faster than would actually be driving and your drive train will not be damaged.
Old 05-03-2010, 10:38 PM
jcknthegrn's Avatar
As a side note I've been running 33" tires for the last 2 years with stock gearing and no problems.
Old 05-03-2010, 10:57 PM
yotaman85's Avatar
I don't think you could run big enough tires on an unmodified 4runner to hurt the drive train considerably enough to worry about it..
Old 05-03-2010, 11:42 PM
Matt16's Avatar
If you're going from a 265/70r16 to a 255/70r16, then you're going to a smaller tire. Smaller tire means the truck will accelerate quicker, but will be reving higher on the highway. If you meant a 255/85r16, then that's a true 33" tire and you'll lose a bit of acceleration, but you'll rev less on the highway.
Old 05-04-2010, 09:46 AM
Rspct2All's Avatar
Excellent, thanks everyone!
justdifferentials
Just Differentials
09-17-2015 06:14 PM
09-04-2015 09:27 AM
94ofCanada
08-14-2015 06:37 AM
nickbeauregard
12
08-07-2015 06:04 AM
Michael oaks
07-27-2015 11:47 AM
Quick Reply: Any harm to the drivetrain by going with bigger tires?
