Antifreeze smell
Old 09-05-2012, 03:59 PM
FJHammerHead's Avatar
Antifreeze smell
Yesturday, I went to go to work and as soon as I got in the 4runner I smelled antifreeze. The front and rear carpet are bone dry and the smell wasn't coming from the vent. The radiator is full and the overflow was not full nor empty. Does anyone know what else I should check?? Thanks
Old 09-05-2012, 04:00 PM
22repower's Avatar
Hoses in the engine bay leaks can be hard to spot.
Old 09-05-2012, 05:16 PM
totally a bro
Staff
vital22re's Avatar
water pump may be starting to fail.
Old 09-05-2012, 05:44 PM
Chimpy's Avatar
Have a pressure check ran on the radiator. Could be a tiny pinhole leak. They can be hard to find. If there is a leak the pressure will run off and show on the gauge.
Old 09-05-2012, 06:47 PM
rworegon's Avatar
Use a mechanics mirror and a flash light looking for the tell-tale red or green crust from the leak. Also, check carefully at the head block interface. Could be a small external seep through the head gasket.
Old 09-06-2012, 02:26 PM
Thanks for all the info.
Steven.m.paulk
06-07-2020 10:45 AM
puddlepirate
07-30-2016 06:29 PM
Buckaroo_Banzai
09-24-2015 07:26 AM
themightykhoner
09-18-2015 02:28 AM
Ott47
09-14-2015 12:09 PM
Quick Reply: Antifreeze smell
