Antenna Question
Old 03-20-2012, 07:13 PM
Canadian Bacon's Avatar
Antenna Question
I haven't been on the forums for a while, but I remember seeing way back when, a thread on swapping out the motorized antenna for a standard type, however I can't seem to bring it up on the search.
Could someone please direct to the thread I am searching for or possibly tell me what is involved in the switch over?
Thanks.
Old 03-20-2012, 08:44 PM
JBurt's Avatar
Here's one
http://www.4runners.org/writeups/whip/index.html
Another option is to splice a switch into the power antenna line behind the radio. That way you choose when it is up. There is another antenna in the rear most passenger side window that gets decent reception and you could just put up the power one when you need it. That way is doesn't break in the carwash or on trees.
Old 03-22-2012, 04:19 PM
tunnelmotor99's Avatar
I just cut the power wire to the motor and it stays up all the time, but I can lower it by hand if I need to. I never use the radio though, just an ipod so I should probably just leave it down.
Old 03-22-2012, 04:33 PM
4Voigt's's Avatar
i replaced my power ant. with a regular style on my 98 4runner. All i did was pull the pass. frt. fender liner loose. pull the motor and mast out unplug harness. then pull radio out and disconnect antenna. pull it out. put regular mast assembly in place and route wire back up to radio and plug it in. pretty straight forward.
DeathCougar
04-01-2018 11:29 PM
mussy01
12-13-2016 08:20 PM
makemusic116
08-02-2015 05:23 PM
makemusic116
08-02-2015 04:40 AM
TDonkey
07-26-2015 10:14 AM
Quick Reply: Antenna Question
