Another Toyota Cheap Trick - Under $10.00 - Caution dialup, kinda big pics
Old 02-20-2005, 11:38 AM
azrain's Avatar
For those of us who pull interior panels for access to areas underneath them, you may have experienced what I call the "one time assembly fastener" that Toyota uses on plastic interior panels. These are prone to breaking, stripping out from repeated installation, wear, etc. Here's a pic of an abused panel for a visual example:
As you can see, one of the two fasteners is broken and the other one is well on its way.
Well, I just got tired of panels squeaking and flopping around loose, so I went to ACE Hardware and picked up a handful of nylon panel nuts to give them a try. At a whopping $.26 each, what did I have to lose? As it turned out, these worked perfectly. Here are some pics of the panel nut:
These are meant for a #10 screw with a 3/8" X 3/8" opening. The openings (for the most part) in a 3rd Gen. 4Runner are at least .340 X .340 making these perfect for the application. I did have to drive the panel nuts into the perfectly square openings with a 1/2" ratchet extension and a deadblow, but they went right in. Pics of the installation:
Door sill application
Rear Hatch sill application
After cutting about a 3/8 of an inch off the bottom of the interior panel standoff / fasteners, the door sill went in perfect and are mounted extremely solid using the factory screws. Not bad for about $6.00 and an hour worth of work.
Mike
Old 02-20-2005, 11:43 AM
waskillywabbit's Avatar
Awesome find...I'll have to look into that for my 85.
Cheap and effective is my kinda mod!
Old 02-20-2005, 12:11 PM
ugadawg95's Avatar
Mike
Can you explain this further please? This is EXACTLY what I need to do to my drivers side door sill cover! Great thinking!
Old 02-20-2005, 12:15 PM
Ironmike4x4's Avatar
Sweet! I've had to take mine apart several times for wiring CB's strobe lights, and etc. so that helps out alot. Good job.
Old 02-20-2005, 12:18 PM
Buy the panel nuts. Smack them in w/ a 1/2" extension and a BFH and shave some off your trim piece on the backside so it'll sit flush. Screw it on. You Georgia bulldogs ain't too smart are ya?
Old 02-20-2005, 12:27 PM
azrain's Avatar
That's about the long and short of it.
Mike
Old 02-20-2005, 01:02 PM
Mike
Old 02-20-2005, 01:12 PM
ugadawg95's Avatar
Mike
Thanks Mike. I looked at my local ace hardware with no luck. Was it in with the rest of the hardware in those little drawers? Or was it in another location?
Old 02-20-2005, 01:13 PM
ugadawg95's Avatar
Somehow I knew I was going to get a smarta$$ comment from you.
Old 02-20-2005, 01:22 PM
azrain's Avatar
Yeah, they are in the Hillman drawers (Hillman is a major retail fastener distributor.) They are also likely available at Lowes / Home worthless Depot, etc. I'll try to get the P/N next time I'm in there.
The point of the ratchet extension was to drive the panel nut home since I was too lazy to look for my drift punches and I couldn't get the head of the BFH in there to drive the nuts into the hole. Dang, all of that does NOT sound right, but that's the case...
Mike
Old 02-20-2005, 01:26 PM
ugadawg95's Avatar
Mike
LOL!!!! Thanks Mike, that would be great if you could get the part number. These door sill covers have been driving me nuts!!!
Old 02-20-2005, 01:30 PM
You dawgs are such easy targets!
Old 02-20-2005, 06:34 PM
Jake94's Avatar
Napa part # 665-1002
$5 for a 20 count bag. Used 'em to fix the squeeks in my dash. Worked great.
Jake.
Old 02-20-2005, 06:54 PM
azrain's Avatar
Knew I wasn't the first, thanks.
Mike
Old 02-20-2005, 07:08 PM
Bob_98SR5's Avatar
hey mike,
i had to do exactly what you did when i tore out my entire interior for my sound deadening mod. those things are the best!
they also work in the holes for the fender flare bolts.
bob
Old 02-21-2005, 05:46 AM
TRDDude's Avatar
Thanks for the tip!! I just broke those tabs this past weekend on my door sills.
Old 02-26-2005, 04:53 PM
ugadawg95's Avatar
I picked up some panel nuts at Lowes, snapped them in and re-installed the door sill covers. Great idea!!!
Old 02-26-2005, 06:24 PM
rwmorrisonjr's Avatar
Location: Home: Aurora, CO; Work: The People's Republic of Denver
Awesome idea, something to pick up at Lowe's this week.
Old 02-26-2005, 06:42 PM
Rick F.'s Avatar
Location: Far western Kentucky (transplanted from central PA)
Kudos, gents! A great solution for a common problem!
Spicer
06-10-2020 08:39 PM
6th Gear
19
12-10-2019 07:31 AM
Jmiller1023
23
08-06-2015 07:03 PM
shadowbirdie
06-18-2015 06:38 PM
Quick Reply: Another Toyota Cheap Trick - Under $10.00 - Caution dialup, kinda big pics
