Amsoil Oil Filter for 3.4 Question
Old 02-29-2004, 07:45 AM
ElwayLite's Avatar
I was getting my numbers together for my order and noticed that the oil filter number for my yota is the same as my saturn work car, I thought this was strange, anyone run into problems with any part numbers while ordering from Amsoil?
Old 02-29-2004, 11:05 AM
no problems for me...
Old 02-29-2004, 11:06 AM
Hyperlite's Avatar
Did you try to swap the saturn one with your truck
Old 02-29-2004, 09:41 PM
Mossback74's Avatar
Same filter works on the 3.0 too.
Old 03-01-2004, 09:23 AM
tomstin's Avatar
I use the SDF 34 in my truck. A little snug getting in there but the additional filter area can't hurt.
Old 03-01-2004, 09:41 AM
ElwayLite's Avatar
I think the recommended is the SDF57
Old 03-01-2004, 11:55 AM
tomstin's Avatar
Best guess is the SDF 34 is 20 - 30% larger. Gadget is the one that figured this out.
Old 03-01-2004, 12:12 PM
ElwayLite's Avatar
So the 34 is larger and a tight fit but fits. Thats not a bad idea then I mean more filtration area never hurts.
Old 03-01-2004, 03:48 PM
Gadget's Avatar
Yep, I figured it out, the SDF-34 works just fine. It is exactly the same filter as the SDF-57 except slightly longer. Same threads, same pressure bypass valve and everything else, just more filter area so there will be less restriction to flow, and it will hold more crude before flow it restricted.
Gadget
Old 03-01-2004, 05:22 PM
Rick F.'s Avatar
Location: Far western Kentucky (transplanted from central PA)
The oil filter on my son's '96 Saturn SC2 is the same one I use on my '00 3.4L.
Old 03-01-2004, 05:31 PM
humanoid's Avatar
Gadget
Gadget:
Will they fit in a '99 Pre Taco?
Old 03-01-2004, 05:55 PM
Gadget's Avatar
Yep, and if you want to order one or some oil, or sign yourself up as a dealer or a preferred customer or what ever, click here:
www.GadgetOnline.com/AMSOIL.htm
Be sure to download and read the Motor Oil Bible.
Gadget
Mulkey's Avatar
What about Napa Gold filters? Would the same situation apply?
Old 03-07-2004, 04:02 PM
tomstin's Avatar
OK, change the filter on my tacoma, forgot to get this picture with the new filter, but this shows the difference between the SDF 57 and SDF 34 Filters
Old 03-07-2004, 04:05 PM
ElwayLite's Avatar
cool!
smthwsn357
05-01-2024 07:28 AM
Eggslinger
06-08-2019 03:32 PM
thefishguy77
07-30-2015 10:59 AM
Coreyr384
07-10-2015 11:13 AM
Cplmike
07-08-2015 08:47 PM
Quick Reply: Amsoil Oil Filter for 3.4 Question
