Alarm ECU missing!
Old 08-16-2011, 07:18 AM
Dodger's Avatar
Alarm ECU missing!
This thread: Alarm ECU locations sez my 1998 4Runner alarm ECU should be under my drivers seat. There's a CD changer under there but nothing else. Any idea wazzup? I have power door locks, and my truck came with a non-working remote, I'd like to program it.
Old 08-17-2011, 10:53 AM
Qyota's Avatar
What does your remote look like? If two buttons (lock and unlock), you probably have the dealer-installed RS3000 system, and the brain should be under the driver seat. Someone might have relocated it to put the changer under there. Check under the carpet too.
If your remote has 3 buttons (lock, unlock, rear window), you have the factory-installed system, which has no separate ECU. Programming is different between the two systems.
The other option is that you have an aftermarket alarm...in which case I can't help you!
Old 08-18-2011, 05:43 PM
narfy's Avatar
post a picture of your alarm remote... if it's an RS3000, then i have a spare brain, BNIB
mussy01
12-13-2016 08:20 PM
shisha1999
09-20-2015 11:44 AM
sanctfy
All Other Toyota Swaps
09-15-2015 02:52 PM
corey519
08-12-2015 11:12 AM
jetspeedz
07-13-2015 09:32 PM
Quick Reply: Alarm ECU missing!
