ADD Solenoid Question
Old 07-24-2008, 07:56 AM
pray4surf's Avatar
Regarding vacuum actuated ADD
Are the VSV2 and VSV4 solenoids constantly energized? (individually).. If I'm driving around on the street in 2WD, is the VSV2 solenoid getting constant power, or is the power momentary and once the clutch sleeve is in the 'dis-engaged' position is the solenoid de-energized? And Vice-versa for 4WD and the VSV4 solenoid?
Old 07-25-2008, 09:03 AM
pray4surf's Avatar
BTT - anyone?
Old 07-25-2008, 04:50 PM
eric-the-red's Avatar
In 2nd gen 4Runners they are constantly energized, this keeps a constant vacuum source to the actuator. Not sure about newer vehicles but I would think it's the same.
Old 07-25-2008, 06:55 PM
pray4surf's Avatar
Thanks, should be easy to confirm with a DMM. I'm at the wiring stage of my conversion to 4WD - finding out I don't have (from the factory) certain relays and connectors on my 98 PreRunner. Creating my own ADD VSV solenoid harness, powered by switch in cab or position switch on the tcase... Wasn't sure if constant power to the VSV solenoids would burn them up...
Old 11-02-2013, 08:37 AM
Gevo's Avatar
SOrry, I know old thread.. but my question is related and isn't worth a new thread
SO, I toook my ADD actuator off to remove the front diff cover and so on... I marked which hose goes to which side of the actuator, during the removal process i pulled the two vac hoses aside and both of them had a splice with a mickey moused plastic tube that I hadn't noticed, so the tips were pulled off... result? I don't know which VSV is for which side of the actuator. I tried to use the fsm, but my problem is that I can't find which in the car is VSV2 and which is VSV4. Can't energize the system yet to see which is normally on/off, so..
Can someone tell me which color VSV is VSV 2 and VSV4?
Thanks gentlemen!
EDIT: I just realized this is in the wrong forum, I'm 1991 4Runner 3VZE!
chuckross1957
06-28-2019 10:19 PM
Bawlzdeep
08-02-2015 08:35 PM
defrag4
07-31-2015 10:50 AM
jgwerth
07-16-2015 03:23 PM
mengquis
07-13-2015 10:39 AM
Quick Reply: ADD Solenoid Question
