ADD relay location.......
Old 07-06-2003, 10:44 AM
VolcomTacoma's Avatar
Anyone know exacltly were the ADD relay is? I know it's under the instrument panel on the passenger side of the steering column, but I can't find it. Do you have to take apart the dash? Thanks
Old 07-06-2003, 03:47 PM
UKMyers's Avatar
I am not sure exactly where it is but pretty sure you'd have to remove some stuff to get to it. I know when I hit 4WD I can hear the relay click somewhere behind about where the key is or so. A FSM would probably show you the location. Lot's of guys on here have them. Good Luck
Old 07-06-2003, 03:54 PM
Co-Founder/Administrator
Staff
Corey's Avatar
Here's an online CD FSM.
http://www.net-impress.com/4runner/cd/
You might find where the relay is in there.
Old 07-06-2003, 09:13 PM
Yeah, the CD FSM showed were it is at. Thanks for the help guys.
Old 10-18-2010, 04:43 PM
99yota4's Avatar
super old thread, hoping someone can point me in the right direction for the ADD relay. I called toyota and they said my 4runner was solely controlled by the 4wd ECU in the driver side kick panel, which i think is BS! I have a 1999 4runner 3.4L with J-shifter. automatic. Any help would be greatly appreciated!
Old 04-16-2018, 12:25 PM
jnstealth's Avatar
VolcomTacoma. Why wouldn't you go as far as to post the actual answer to your question once you found one?? Isn't that the point of these forums. Help a brother out!!
Old 04-16-2018, 05:40 PM
old87yota's Avatar
The last reply from VolcomTacoma was in 2003.
VolcomTacoma has not logged into YotaTech since 2006.....
Old 04-16-2018, 06:08 PM
habanero's Avatar
He might've not thought about the link going bad. Anywho...
http://www.toyota-4runner.org/3rd-ge...-location.html
w/pic of said relay post#3 though post#5 confirms it as for a 1999 for a 4wd manual trans. Another thread on expedition portal mentions the same place for a 98 auto tranny 4Runner. Good ol' Google.
I'm not popping my front passenger sill and kick panel to confirm, it's too cold and I don't currently need the answer. You can do it for your ownself if you wish, then go ahead and help others with a post and pic of wherever you do find it.
Old 04-17-2018, 09:10 PM
TheDurk's Avatar
If you want help, you should post your year and transmission. I will confirm that '99 manual is as pictured above. There are many different configurations of transmissions and the components move around.
Old 07-17-2018, 12:46 PM
dpoupard's Avatar
ADD relay location for Automatic Tran
Does anyone on this thread know where the ADD relay is for a automatic transmission? I have a 2002 limited with auto transmission. I'm not sure if they are in the same location. Any help would be appreciated!
Also, my 4x4 is engaging and disengaging on its own. I do not have the 4wd switch on, but it will sometimes jump into 4wd and then jump out a little while later. Any thoughts?
Old 07-17-2018, 07:45 PM
TheDurk's Avatar
Taco or 4Runner? If 4Runner, no ADD relays in 2002 as no manual trans made. Just 4wd ECU.
http://www.teamtoyota4x4.org/archivi...mci/0394wd.pdf
Taco I have no idea.
Describe your problem better. How do you know it jumped into 4wd? From the light, or the way it drives, or what?
Old 07-18-2018, 05:40 AM
dpoupard's Avatar
It is a 2002 4runner limited. So, if I am reading it correctly, you are saying there is no ADD relay in my vehicle.
As for the arbitrary engage/disengage, the lights on the dash are always blinking. I know it jumps into 4x4 by the way it drives. It never happens when I am driving straight down the road. It does it at slow speeds and usually when I'm making a sharper turn like into a parking space or my driveway. It may remain in 4x4 for a day or less or it may return to 2wd the next time I start it up and drive off.
Old 07-19-2018, 11:21 AM
dpoupard's Avatar
bradahman
10-01-2015 09:24 AM
JookUpVandetti
09-30-2015 08:58 AM
Cycles
09-29-2015 06:37 AM
JPV
09-28-2015 03:15 PM
Rcbc92
09-26-2015 03:00 PM
Quick Reply: ADD relay location.......
