99 manual shifter knob to 05 auto shifter knob mod
Old 11-25-2008, 11:14 AM
TC4RNR's Avatar
my stock leather shifter knob was all messed up after 10 years of use, and it has a weird smell, too. i don't wannt an afermarket one because most of them are either aluminum or plastic. i really like the newer model auto trans shifter knobs because they are bigger and more comfortable but the threads are different. stealers want $80-100 for a replacement leather knob, that's way too expensive for me.
here is what i did, i bought a Tacoma shifter on ebay for $25, a grade 10.9 M8 bolt for $0.80.
first, removed the shifter lever assembly, then cut the lever with a band saw.
rounded the hex bolt to proper size using a belt sander, to it fits right in the hollow shifter lever. then tig welded them together, re-installed the lever assembly.
screw the knob on
here is the final result
the whole thing took me about half an hour from start to finish, probably would be an hour if i did have a belt sander and band saw. tig welder is better but mig will do just fine, only needs more cleaning afterwards.
Old 11-26-2008, 10:27 AM
Ron Helmuth's Avatar
Looks nice but I am clearly missing something-can't you just unscrew the 99 knob and replace it with the 05 knob?
I like the Momo woodgrain knobs myself but the newer Runner one looks nice also.
Old 11-26-2008, 10:29 AM
881stGenRunner's Avatar
amazing job that looks really good and it matches very well!
he said they were different thread pitches
Old 11-26-2008, 10:57 AM
TC4RNR's Avatar
nope. differen thread size and pitch. 10mm(99 4Runner 5spd) vs. 8mm(05 Taco auto)
Old 11-26-2008, 11:03 AM
tj884Rdlx's Avatar
nice work man! when you got welding skills, may as well use 'em!
Old 12-02-2008, 08:32 AM
thanks I missed that
thanks I missed that detail, thanks for filling me in
Liadrin
04-25-2022 02:54 PM
jbandt
08-03-2015 03:23 PM
TransAmBandit
07-28-2015 11:30 PM
rushw
07-18-2015 01:46 PM
cyclist231
07-07-2015 12:56 PM
Quick Reply: 99 manual shifter knob to 05 auto shifter knob mod
