99 4Runner "stumbling" at idle and acceleration
Old 12-19-2010, 08:10 PM
99_Runner's Avatar
Hey guys. I need some help here. I have a 99 4Runner with the 3.4 and about 225k miles. All of a sudden it's "stumbling" when sitting at idle. It runs fine then "stumbles" for a second then runs fine for about 20 seconds then "stumbles" again. Also on acceleration when you first start out it seems to miss right at first then runs fine. Once you are moving it runs fine. It only does this when you are moving very slowly, especially when backing up. It actually seems like it's going to die when you are backing up it's so bad.
I've replaced the fuel filter and it fixed it for a minute, at least long enough for me to drive it. Then when my wife drove it about 20 minutes later she said it's still doing the same thing. We are going on about a 500 mile trip here at the end of the week so I'd like to get this figured out. Also, no check engine light is on.
Thanks for all your help.
Old 12-19-2010, 08:49 PM
brian2sun's Avatar
How old are the plugs and wires?
Old 12-19-2010, 09:11 PM
totally a bro
Staff
vital22re's Avatar
plugs, wires, clean the maf. Other wise check for codes in the history.
Old 12-19-2010, 10:01 PM
James Woods's Avatar
X3 on plugs and wires.
Old 12-20-2010, 03:10 AM
TheDurk's Avatar
All of the above and clean throttle body, too.
Old 12-20-2010, 05:53 AM
99_Runner's Avatar
Plugs were replaced this summer. I haven't had a chance to do wires yet. I'll pick some up today and do that along with cleaning the MAF and throttle body tonight and let you guys know.
Old 12-20-2010, 06:30 AM
BigBallsMcFalls's Avatar
maf can do this when dirty
Old 12-29-2010, 07:22 PM
99_Runner's Avatar
FIXED. Replaced the wires, had the originals on it at 225k, and plugs. Running great now.
Old 12-29-2010, 09:34 PM
CodyX36's Avatar
Whew, those were some old plugs! :O
But yeah, had this problem a year and a half or so ago, got them plugs and wires swapped out for some new ones, ran great!
Old 01-09-2011, 07:06 AM
scrpydoo8's Avatar
plugs and wires.. it happened to me quite a bit
Old 09-08-2014, 05:02 PM
MB4runner's Avatar
BUMP
I have exact same problem 99 4runner 3.4, stumbles/hesitates in reverse and idling in drive. Seems normal once up to speed.
Replaced: MAF, Plugs, Wires, Tested Coil packs they in spec, No engine code. Any ideas?
Old 09-10-2014, 06:43 AM
MB4runner's Avatar
FIXED
For anyone else... It was a bad coil. Even though it tested to spec with the multi-meter it was somehow still bad. Oh well, 350,000 KM and runs good again!
Old 09-10-2014, 07:48 AM
wii_tarded's Avatar
How often is it recommended to replace the coils? And is there a difference between the coils for a 96 and a 2000?
Charecter1
11-06-2023 10:08 AM
icentropy
09-16-2020 02:47 PM
smiley52
07-11-2015 05:16 AM
Jnkml
07-06-2015 01:20 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: 99 4Runner "stumbling" at idle and acceleration
