99 4Runner Auto -- Shifter Knob Removal????
Old 05-23-2009, 06:09 AM
ramo5150's Avatar
Hi ALL...
I need help removing the shifter knob of my 99 4Runner Auto w/OD. I can't seem to be able to disconnect the wires that connect the OD button. I have pop out the OD housing but there two white wires attached to the contacts of the OD switch. Is there something i'm missing to take the knob out. I'm stumped and will appreciate any help....
Thanks in advance.....
Ramo......
Old 05-23-2009, 06:38 AM
4Runner202020's Avatar
where are the wires running... would it be easier to disconnect them from the other side. just a thought.
bobby
Old 05-23-2009, 07:44 AM
ramo5150's Avatar
bobby
I followed them to a connector under the shifter housing and they go into a plug but not removal.
Old 05-24-2009, 12:34 AM
KZN185W's Avatar
the white socket has a lock. i think it needs to be pulled up first then you can start pulling the 2 white wires with a teeny-weeny screw driver by pushing on the individual locks of the wire prong
Old 05-26-2009, 12:34 PM
ramo5150's Avatar
is that inside the socket plug???? I've determined that is where it has to come off from other than undoing the metal shifter..... i'll update soon with the results..... Is snaking the wht wire combo through shifter a pain???? is there something to make it go through simply???
Thanks in advance,
Ramo
Old 05-27-2009, 03:58 AM
KZN185W's Avatar
the socket lock is on one of the wider side of the socket.
there is no socket plug. it's a one-piece socket, not a male and female socket pair.
the two white wires go to that white socket. snaking the two white wires is easy since it comes out from the bottom of the shifter. just make sure that they don't get snagged when the shifter is moved back and forth.
Old 05-27-2009, 07:11 AM
ramo5150's Avatar
"then you can start pulling the 2 white wires with a teeny-weeny screw driver by pushing on the individual locks of the wire prong"
Thanks KZN, I really appreciate the help,
but this is where i'm having my issues. I can't seem to get the 2 wht wires off the prong. i can see inside the prong/plug(where it seems to be a tiny locking clip but no movement i make to remove or pull the wht wires free releases them)..... Any other ideas or places i can see the prong/plug having some of their connectors removed or disconnected......
I'll try and post some pix of the plug and issues i'm having.....
Thanks again.....
Ramo
Old 05-29-2009, 02:15 AM
KZN185W's Avatar
that's where the teeny-weeny screw driver comes in.. you use it to push the prongs upwards so the clip-lock is pushed upwards and then you can pull the wires.....but do all this after you have pulled the plastic lock on the socket upwards...
06-01-2021 01:51 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
MTLroadierunner
07-15-2015 12:58 PM
cyclist231
07-07-2015 12:56 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 99 4Runner Auto -- Shifter Knob Removal????
