99 4runner, 3rz oil leak
Old 03-05-2009, 09:17 AM
fyrfytrryn's Avatar
hello everyone.
ive got a 1999 4runner with a decent oil leak. it leaks about a half qt a week. as far as i can tell, its leaking from the front facing part of the 90 degree deal that holds the oil filter (is there a name for this?). thats where it seems to be starting, and it runs down to the pan, lines,and skid plate. its not a substantial leak so im going to wait until my next oil change and steam clean the whole area prior to tearing into it. is there a gasket that goes between the block and this adapter? how should i go about fixing it? pretty common? thanks guys, pics are coming very soon.
Old 03-05-2009, 09:27 AM
scuba's Avatar
Yes, Pics would deff help...
Old 03-05-2009, 09:39 AM
Staff
DeathCougar's Avatar
Just use some dealybop dohicky to fix the seal majig.
Sorta tough to tell without a picture, exactly what you are referencing there
However, assuming you are talking about oil filter adapter housing, yes there is a seal that goes between that and the block. Could the oil be from changing the filter? Every time I remove the filter on any of my cars I make a giant mess from oil running down all over the engine.
Old 03-05-2009, 09:46 AM
fyrfytrryn's Avatar
no, theres a spot where the oil is "washing" the block, moving dirt from the area. pics are uploading to photobucket and will be posted as soon as this connection allows. do you guys have a sealer or # for a gasket, becasue autozone has no idea what im talking about (no suprise)
Old 03-05-2009, 09:48 AM
Staff
Toyota will know what you need. Contact your local dealer, or just go in there and look at their microfiche of the parts layout.
Old 03-05-2009, 10:09 AM
fyrfytrryn's Avatar
here ya go guys
http://smg.photobucket.com/albums/v6...Truck/4runner/
fyrfytrryn's Avatar
here ya go guys.
Old 03-05-2009, 11:31 AM
BigBallsMcFalls's Avatar
1/2 quart a week is a big leak. could blow out anytime and lose all yer oil
in 2 minutes
Old 03-05-2009, 11:58 AM
raydouble's Avatar
Definitely looks like you need an oil filter mount/adaptor to block gasket, should be cheap from the dealership.
Old 03-05-2009, 12:34 PM
pat161's Avatar
Having had 2 3rz Tacomas and 1 3rz 4Runner I will weigh in. The 4Runner is a little different then the Tacoma in that they have an oil cooler that the filter screws into. On the Tacoma the oil filter housing is just a flat piece of metal, on the 4Runner it is a little bigger and has coolant lines running through it to cool the oil as it enters and leaves the filter element. I imagine you could replace that part, but first I would check 2 common things. First make sure that the last time the oil was changed the old gasket didn't get left on, double gaskets can cause leaks. Second make sure you are putting a light coating of oil on the gasket before installing the filter.
Old 03-05-2009, 06:38 PM
fyrfytrryn's Avatar
thanks for all the help guys. i got the gasket from toyota of redlands for 3.00 and some change. the diagram the parts guy printed for me shows the lines you mention pat161, but i dont have any of those. leak is fixed, and oil is changed. thanks yotatech!!!
Old 06-01-2009, 08:48 AM
ramo5150's Avatar
Thanks all, this was really helpful.......
Old 05-25-2012, 06:32 PM
bmackinney's Avatar
How to remove bracket?
I have the same leak, I think. Do you need a pnuematic wrench to remove the bracket? My ratchet will not move on the sucker.
Old 05-25-2012, 06:42 PM
fyrfytrryn's Avatar
Nope, no air tools for me.
bigjstang
08-25-2021 12:41 AM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
Yota.Jay
07-23-2015 08:08 PM
Avenged
07-09-2015 07:55 AM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 99 4runner, 3rz oil leak
