99 4 runner inner fender removal
Old 05-05-2005, 06:54 PM
filter's Avatar
Hello
I'm trying to remove the front inner fender to access a broken power antenna on my 99 4 runner. How do you remove the plugs that fasten the plastic inner liner and also anchor the fender flares? Is a special tool required?
Thanks for the help..
Old 05-05-2005, 07:06 PM
george16's Avatar
Check Bob's write-up for replacing the antenna. It has detailed pics and instructions in removing the inner fender too. Here the link:
Antenna/fender removal
george
Old 05-06-2005, 05:50 AM
filter's Avatar
Thanks
My question is more pertaining to removing the plug itself. Do you simply pry them off? Looks like this is impossible without damaging them. Are these plugs something that needs to be replaced once removed?
Thanks
Old 06-06-2006, 09:56 AM
jwbehm's Avatar
I am midway through this mod right now and have encountered the same problem, how do you remove the plugs!?!?!
Old 06-06-2006, 10:42 AM
jwbehm's Avatar
Nevermind, I just ripped them out. Hopefully toyota will be able to give me 2 replacements
Old 06-06-2006, 11:08 AM
Bob_98SR5's Avatar
yes, just rip them or drill them out and buy replacement plugs
Old 06-08-2006, 08:59 PM
GREEN4SKIN'R's Avatar
Sorry I stumbled across this thread a little too late but these clips are (relatively)easily removed by first removing the screw (some might not have screws) that is in them then using a pick tool (like an ice pick with the last 1/2" of the tip bent to a right angle) poked into the hole and pry the barbs (2) into the center of the hole. A little difficult to explain in words but I recently replaced the mast on my power antenna without breaking any of the clips. Hopefully this helps someone in the future. Or heck, you could just buy new clips.
Old 06-09-2006, 04:25 AM
jwbehm's Avatar
Yeah the new clips were all of $0.69 each, not too bad. I will get the part number later tonight if i can find the reciept.
Old 06-09-2006, 06:05 AM
snap-on's Avatar
you can get generic plastic rivits at the auotparts store. i plastic thinigie of 4 or 6 or something for like $2
and im in the rip them out by any means necessary camp
Old 07-23-2011, 02:38 PM
Krizzle77's Avatar
Great Post... wanted to add to this excellent thread
Following the instructions here I was able to do this with no issues all by my self. I used Ebay (Bridgewood Motorsports) to pick up the antenna mast. My antenna cable was broke so... When pulling the fender shield (after removing the fender flare completely) I simply broke 2 retaining clips (will purchase replacements later) NOT the bottom left one but the two above it. If you simply break those two that gives you just enough room to pull the fender shield back and get at the 10mm bolt holding the power antenna assembly in. I didn't disconnect any cables simply slid the assembly out and using a Phillips unscrewed the 6 screws holding the motor assembly together. Pulled out the broken antenna cable and closed everything back up. I reinstalled and simply extended the new antenna, put the teeth in facing the front bumper and sat on the passenger seat to power the radio on then off and simply fed the new antenna mast and cable into the unit. Done and now only need to buy two retaining clips.
Attached Thumbnails 99 4 runner inner fender removal-img_0762.jpg   99 4 runner inner fender removal-img_0764.jpg   99 4 runner inner fender removal-img_0765.jpg
Old 08-24-2011, 08:38 AM
21ashton's Avatar
Im trying to remove the fender to get to my antenna that is off track and getting mad. lol. I thought i took off all the bolts but it still wont come of , its a 97 toyota 4 runner please help
Old 08-24-2011, 09:08 AM
FormerVendor
ALLDATAdiy INFO's Avatar
Where is it stuck at?
toyota32
07-06-2015 05:42 PM
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 99 4 runner inner fender removal
