98 Tacoma lift problem
Old 01-21-2009, 11:43 AM
Gerdo's Avatar
Originally Posted by tyhuck
my second question is, Should the strut still be on the truck even thought there is a coil-over shock on it.
The "strut" that is closest to your tire replaces the UCA. It keeps the tire/wheel located and moving in a straight line verticaly. Without it your wheel would lean in and out. On a stock truck your UCA does this (and looks just like your lower control arm). The UCA was remover and replaced by the "strut". The stock UCA was not reused because it would have been at full droop and binding. Some lifts get around this problem by usinbg an upper ball joint spacer. This allows the UCA to be at the same angle as the LCA. (this is a good thing, this allows the wheel to travel up and down in a straight path) The LCA is lowered by the bracket lift, allowing it to be ~ factory angle.
Old 03-01-2014, 06:29 AM
plowright's Avatar
I have the same lift on the 96' tacoma i just bought and where the "secondary strut" mounts at the the top the bushing is practically gone. Would i be able to remover that strut and replace it with an upper a arm? and with that bushing being so worn out the top of the strut is falling inward causing the tire to camber
Old 03-01-2014, 11:21 AM
turbo8's Avatar
If you get rid of the lift and all the stock suspension mounting locations are still there, then yes you can put the upper arm back on.
09-04-2015 09:27 AM
Seattle_Sign_Guy
07-12-2015 12:38 PM
Poncho0206
07-10-2015 06:21 PM
Yotoder865
07-09-2015 07:51 PM
akaphilly
07-09-2015 02:18 PM
Quick Reply: 98 Tacoma lift problem
