98 tacoma leaking oil behind crankshaft pulley.
Old 02-28-2013, 11:36 AM
mlawrence17's Avatar
I've got a '98 tacoma prerunner with 140,000 miles. Its leaking oil behind the crankshaft pulley. I'm assuming there's some type of crankshaft seal that needs to be replaced. My plan was to replace the three belts and check out the timing belt....or should I just go ahead and replace the timing belt since I'm half way there? What about the water pump? Anything else? Someone recommended this kit.
http://www.ebay.com/itm/Toyota-TIMIN...item2a144a37e8
any thoughts??
Old 02-28-2013, 11:59 AM
rworegon's Avatar
Excellent kit.....many here, including myself, have used it.
Do it all while you are in there. Buy a new crank bolt from the local dealer as it is a non-reusable part.
There are a couple of other 3.4 timing belt threads in past 2-3 days.
Old 02-28-2013, 03:34 PM
98SR54RUNNER's Avatar
Came to say this.
smthwsn357
05-01-2024 07:28 AM
Eggslinger
06-08-2019 03:32 PM
jakebarrett
07-10-2015 07:15 PM
Coreyr384
07-10-2015 11:13 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: 98 tacoma leaking oil behind crankshaft pulley.
