98 Tacoma Engine Swap, Suggestions?
Old 01-30-2014, 10:10 AM
98yotaman's Avatar
Question 98 Tacoma Engine Swap, Suggestions?
I am replacing the engine in my V6 98 Tacoma after the old one died, does anybody have suggestions on a new clutch, water pump, or even upgraeds I could do?
Old 01-30-2014, 12:39 PM
98SR54RUNNER's Avatar
I know nothing about clutches and MTs, but as far as the water pump and other engine accessory stuff, go OEM all the way. If you're going to go through all the trouble to pull the old engine out, you may as well go ahead and splurge for OEM timing belt, water pump, pulleys, tensioner, etc. It's obviously incredibly easy to do this stuff while the engine is out. If you're going to spend the bucks to breathe life back into your rig, you should do it right.
Old 01-30-2014, 02:43 PM
98yotaman's Avatar
Thanks, I will look into it.
Goddamnboh
3.4 Swaps
12
05-11-2016 09:22 PM
vasinvictor
01-20-2016 12:39 PM
noahstancik
07-10-2015 11:18 AM
greenbuggy
06-28-2015 10:40 AM
Alex Bessinger
06-28-2015 10:05 AM
Quick Reply: 98 Tacoma Engine Swap, Suggestions?
