98 4runner high idle after TB cleaning
Old 01-27-2013, 01:36 PM
98 Black SR5's Avatar
I installed an CAI today. I cleaned my MAF using MAF cleaner. I used carb cleaner in my TB. I now have a high idle, like around 1800-2000. I took it for a short drive and no change. What should I do next? Does it need some more drive time to relearn? Thanks
Old 01-27-2013, 02:02 PM
turbo8's Avatar
Search around this happens quite often. Search for my user name I have posted in a couple of the threads.
Old 01-27-2013, 02:11 PM
hambob's Avatar
I had the same problem. I cleaned my TB and IAC and my idle was suddenly 1700rpm. My butterfly valve wasnt closing all the way but the dirt was providing a seal, so when I cleaned the valve, air would get past and would behave like i was pressing the throttle. I realized that I could manual close the valve and It would idle down but as soon as I pressed the throttle again it would get stuck in the position. so I put an extra throttle return spring and its perfect now. There is a thread that explains exactly whats happening. the valve is actually moving sideways and getting stuck. The way the other guy fixed it was by putting a washer on the valve axle to center the valve and it worked. here is a link https://www.yotatech.com/forums/f2/m.../#post52033152
good luck
Old 01-27-2013, 04:13 PM
4Voigt's's Avatar
disconnect the battery for 30 sec or so. then let it warm up a couple mins. test drive.
Old 01-28-2013, 02:45 PM
I disconnected the neg cable and let it set for 2hrs. Hooked it back up and still same thing. Is there a way I messed up the IAC with carb cleaner?
Old 01-28-2013, 02:58 PM
rworegon's Avatar
Did you take the TB off and remove the IAC to clean it?
All vacuum hoses attached correctly?
Old 01-28-2013, 03:23 PM
I didn't remove the tb. Just sprayed in it with darn cleaner and wiped it out with a clean rag. Do I need to r&r the iac to do it properly?
Old 01-29-2013, 06:43 AM
BigBallsMcFalls's Avatar
reset ecu by pulling battery
wait 10 minutes
reconnect, drive around
should resolve itself
Old 01-29-2013, 03:30 PM
rworegon's Avatar
wait 10 minutes
...and if it doesn't resolve itself, you may have a piece of crud stuck in the IAC or the butterfly is sticking open.
Old 02-06-2013, 09:20 AM
COLO4Runnr's Avatar
Where is the IAC valve at? I replaced that hose and cleaned the throttle body while in there. I too am experiencing high idle. Want to go through a good process before doing the washer trick.
Any ideas on the washer size?
I'm thinking below will be my process:
1. Disconnect/reconnect the battery and see if that fixes it.
2. Check IAC
3. Washer trick
Old 02-06-2013, 11:10 AM
Swede's Avatar
The washer i used was just big enough to slip over the rod. You may have to play with the thickness of it by filing it down to get the throttle valve positioned correctly in the bore. Very simple to do.
Old 02-06-2013, 11:24 AM
What's the washer trick?
Old 02-06-2013, 12:03 PM
COLO4Runnr's Avatar
The washer trick...
https://www.yotatech.com/forums/f2/my-high-i.../#post52033152
Can I do this with the TB still attached or will I have to pull it off?
JF9243176
10-08-2017 04:21 AM
Cesarl74
04-23-2016 06:07 PM
Jmiller1023
23
08-06-2015 07:03 PM
94 Newbie
07-06-2015 04:23 AM
Quick Reply: 98 4runner high idle after TB cleaning
