97 4Runner rear suspension
Old 08-23-2011, 01:49 PM
jgb4runner's Avatar
Need some help with a problem. Took my 97 4Runner 4wd sr5 into local dealer a couple months back for some routine maintenance. I was told my vehicle never had the rear suspension recall done so I had them order the parts and do it even though there wasn't any problems with it. Ever since then the rear seems to be lower than it was before; I took it back to the dealer and they said it looked normal. Last week I took it to another toyota shop, not a dealer, and they said the springs and 'cone springs' looked new but it was riding on the cone springs and that the recall work must not have been done right. i read on here and elsewhere on the internet that 2wd springs are shorter than the 4wd springs and was wondering if they might have used the 2wd springs by mistake. I'm reluctant to take it back to the dealer since they already said it 'looked normal' once. Was hoping someone on here might have had a similar situation or maybe an experience which would help me figure out what went wrong and how to correct it. Thanks.
Old 08-23-2011, 02:48 PM
Staff
DeathCougar's Avatar
48231-35130 is a 2WD spring (96-98)
48231-35150 is a 4WD spring (96-98)
Find out which springs they used by looking at your invoice.
Old 08-23-2011, 02:57 PM
rjaudi's Avatar
If you are saying the cone is touching the axle inside the coil then that is bad and any dealer who says otherwise is horrible. That is an additional bump stop they added so you have no suspension if it is touching. I had the recoil done before the lift and it was nowhere near touching.
Old 08-23-2011, 05:47 PM
jgb4runner's Avatar
thanks for the replies, the part listed on the invoice is SPRING, COIL, RR 48231-35141. I'll do an internet search to see if I can find what this spring number is made for but maybe you can tell me as well. I looked at the coil springs and could see the black rubber cone-shaped thing inside the coil which I guess is what the other shop is calling the 'cone spring'; I'll look again to see if it is touching the axle. i'm supposed to go back to the dealer tomorrow and just want to be as informed as possible.
Old 08-24-2011, 09:27 AM
FormerVendor
ALLDATAdiy INFO's Avatar
Just to add to the part numbers.
If your 4Runner did not come with 16" wheels, your Rear Spring part number is 48231-35140
Old 08-24-2011, 09:28 AM
Staff
48231-35141 4Runner 4WD 15" Wheels 1998 To 3-98 $80.69
If you have 16" Wheels, they used the wrong springs.
The cone spring is the black rubber bump stop.
Old 08-24-2011, 11:24 AM
jgb4runner's Avatar
Thanks. Took it in and they were jerks at the dealer when I told them they put the wrong parts on; they said something about this part number superceded that part number and didn't even look at the information on part numbers that I had. I left without having them do anything to mess things up more. Anyone have any experience going to another dealer to have recall/warranty work fixed when the first dealer messed up?
Thanks again.
Old 08-24-2011, 11:43 AM
blake.nemitz's Avatar
call toyota corporate and bleep about it you should be taken care of
Old 08-24-2011, 11:58 AM
jgb4runner's Avatar
unfortunately, i already called the corporate number 18003314331 and they were of no help at all. they just told me that I had to go back to that dealer to resolve things and that they couldn't force the dealer to do anything; meanwhile I found out that they put the wrong springs(recall work) and the wrong shocks(paid for work) on my vehicle. I was just hoping someone had some experience with doing to another dealer to have incorrect recall work repaired/corrected.
Old 08-24-2011, 12:07 PM
waskillywabbit's Avatar
The squeaky wheel gets the grease.
:wabbit2:
Old 08-24-2011, 04:36 PM
jgb4runner's Avatar
thanks for the replies. Was wondering if anyone knows if the difference between the 48231-35141 spring used for the vehicles with 15" wheels and the 48231-35151 spring used for the vehicles with 16" wheels would change the height of the rear end? The only reason that I even noticed a problem is because my 4Runners rear end looks low and am not sure if these two springs are even that different as far as height/length to cause it to look lower.
Old 08-24-2011, 05:18 PM
tunnelmotor99's Avatar
I wish I could get some free springs from toyota...the runner really needs some! Mine are definitely original but according to toyota's site there are no open recalls on it. sigh...
06-01-2021 01:51 PM
MMA_Alex
25
04-18-2017 05:07 AM
icentropy
07-11-2015 07:21 AM
HRDC0R19
07-05-2015 06:43 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: 97 4Runner rear suspension
