97 4R vibration in floor, searched, no results that match
Old 01-31-2013, 08:44 AM
ToyYodaCA's Avatar
New developments
Originally Posted by lim50
Well one more thought .The only other moving part that I can think of that is NOT rpm dependent is the fuel pump. Maybe?
I spent some time testing as many variables as possible this last weekend and found that the vibration is weaker when the A/C is running. This difference was hard to notice while driving with road noise and bumps. I believe this means that the problem lies in the engine compartment and is likely related to the belt-driven components on the front of the block. I'll be checking those out in detail this weekend.
This may or may not be related to this issue, but the car wouldn't start this morning. I believe that I may need a new starter or the current one needs some TLC. Sigh...it's always something!
Old 04-30-2020, 10:48 AM
JLOWBOOTY02's Avatar
I know this sounds crazy but check the running boards if they are equipped. My wife's on the driverside was a little loose and was causing hers. I replaced struts, strut mount, wheel bearing, tire, tie rods, and u joints. The tap was still present on the floor board. Finally figured out the running board was a little loose on the front tightened it up and it was gone.
sgarrett415
08-16-2009 04:43 PM
ahickman
03-03-2009 10:32 PM
AUYota
04-29-2007 06:14 AM
dougm395
09-06-2006 06:17 PM
YotaChick0216
02-04-2004 04:20 PM
Quick Reply: 97 4R vibration in floor, searched, no results that match
